August 25, 2015, 08:43 |
Negative Pressure at microchannel outlet.
vikas yadav
Rep Power: 10 |
Dear all,
I am modelling flow through microchannel with velocity inlet and outflow boundary conditions at inlet and outlet respectively. I am getting negative pressure at outlet, Is it possible to have negative pressure at outlet ? My Operating pressure is 101325 Pa. Thanks!! |
August 25, 2015, 15:12 |
Lucky
Rep Power: 66 |
Negative absolute pressure is obviously non-physical but a negative gauge pressure is okay. You just have a sub-atmospheric pressure at the outlet.
August 26, 2015, 08:54 |
#3 | |
vikas yadav
Rep Power: 10 |
But i am not able to understand how flow will be possible if pressure at outlet is sub-atmospheric. Please help me to understand. |
August 27, 2015, 01:16 |
Rep Power: 13 |
the calculation does not care. If the outlet velocity is higher than at the inlet, then you change the static term to the velocity term in Bernoulli equation. And then, if the inlet pressure is 0 gauge, outlet pressure has to be lower.
Ansys would not do negative absolute, it would throw a warning. I managed to get a few MPa minus in Autodesk fluid sim. |
microchannels, negative pressure |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
