Could you help me to interpretate the results?
Old   November 10, 2009, 10:55
Default Could you help me to interpretate the results?
Li
llrr is on a distinguished road
Hi everyone,
I am running a ventilation system in a room. The air was supplied from the ceiling and exausted from the outlet, see the velocity distribution in attachment. The several squares were used to monitor the heat source specified as temperature boundary condition. When I looked at the distribution of turbulence viscosity ratio, I can see that it didn't distribute smoothly. Is this a problem of the mesh? BTW, I used Fluent 6.3 and SST model. Thanks a lot.
Li
llrr is offline   Reply With Quote
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
Problems with repeating results Lee Siemens 4 May 26, 2006 03:39
benchmark results stefan Siemens 3 September 10, 2001 09:48
