Scheme file for sinusoidal channel flow
Old   November 24, 2009, 10:27
Default Scheme file for sinusoidal channel flow
elobb is on a distinguished road
I am trying to model flow through a channel, Womersley number one, with a sinusoidal pressure gradient. I saw elsewhere on this forum that using a udf with a scheme file to implement it at each timestep is the way forward, though I am having trouble programming the scheme file.
This is the udf and scheme file I started with..
udf...
#include "udf.h"
DEFINE_EXECUTE_AT_END(execute)
real pressure, t;
t=CURRENT_TIME;
pressure=sin(t);; /* The pressure gradient can be a function of time. */
RP_Set_Real("flag", pressure); /* This will store the pressure gradient value in a variable called flag*/
scheme file...
(rp-var-define 'flag 0 'real #f)
(define print
(lambda()
(define nu (rpgetvar 'flag))
(rpsetvar 'periodic/pressure-derivative nu)
Any help would be much appreciated
Regards
elobb is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
