How create GOOD quality animation in Fluent ?
Old   November 8, 2009, 11:52
Default How create GOOD quality animation in Fluent ?
śląskie
maziboss is on a distinguished road
Hello
I created mpg files but the quality is terrible Do You have any ideas how to create much better animation in fluent ? Here is my simple...
Animation
I want to create mpeg files in higher resolution...
maziboss is offline   Reply With Quote
Old   November 8, 2009, 12:38
O.D.Y.'s Avatar
O.D.Y. is on a distinguished road
Hi there,
do you necessarily need mpgs?
Because I'm using PPM images and create animated-gifs with gimp (open source graphic program) and they actually appear to be very good.
O.D.Y. is offline   Reply With Quote
Old   November 8, 2009, 23:58
Anastasios
ageorg is on a distinguished road
Try using tecplot 360 that directly creates animations of high quality!
ageorg is offline   Reply With Quote
Old   November 9, 2009, 02:26
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Only Tecplot or other software like Fieldview
Philipov is offline   Reply With Quote
Old   November 9, 2009, 04:03
JP
srjp is on a distinguished road
If you maximize the image screen before you make the movie, I found that the movie size is bigger and the clarity also better. Make the movie with hmf files instead of ppm (this gives more control on the view, size etc)
srjp is offline   Reply With Quote
Old   November 9, 2009, 07:43
Rok Sibanc
snow is on a distinguished road
Export jpeg files with desired resolution and convert to movie using ffmpeg.
snow is offline   Reply With Quote
Old   November 9, 2009, 21:48
herntan's Avatar
YH Tan
herntan is on a distinguished road
U need to adjust the hardcopy version of before u create MPEG.
For example, after u done the simulation u go to playback.
the playback have a selection on hardcopy and mpeg.
U click into hardcopy, set it as JPEG, and give damn high resolution for it , such as 1600x1200.
after that, u choose mpeg again in playback window.
now u will create a mpeg with 1600x1200 resolution.
i doing 800x600 resolution last time by using this steps, its working fine for me.
Take a try.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   November 22, 2009, 05:57
śląskie
Take a try.
You have right but i think the mpeg still has bad quality... I'll be write to ppg images and create from this files movie. Thanks for all !
Animation Error in Fluent Andrew FLUENT 9 October 1, 2020 16:42
How to create non-uniform velocity profile in FLUENT? pankaj FLUENT 7 October 24, 2016 04:52
Good Switch deal from CFX to Fluent User who switches CFX 6 May 17, 2006 13:00
fluent animation techniques khalil FLUENT 3 March 22, 2002 15:15
Fluent Animation FP Mie FLUENT 1 August 3, 2001 21:31
