3D multiphase micro model: mixing effect of air and water at the T junction |
November 25, 2009, 05:49 |
Ehsan Fareed
Hi All,
I have a T shape (3D) micro channel, from the left air enters and from below water enters (both are velocity inlets), the flow is laminar, time unsteady, VOF model. I want to see the mixing effect of air and water at the T junction. It is supposed to be a bubble formation at the junction and the bubble is then carried away with the air flow to the outlet (pressure outlet). But what I get is that water level starts to rise in the channel and there is no mixing effect or bubble formation, I get a clear phase boundary between air and water, you can see the picture. http://yfrog.com/ek61388547j I dont know what is the problem, Also I want to use PTFE as a wall material to see its effect on the water as it is a hydrophobic material, but I am unable to define a User Define Material Database for PTFE. Also I want to know that which property of PTFE should be given which defines its hydrophobic character. Please help me in the above 2 problems I am having regarding the mixing effect and the PTFE material, I shall be thankful to you. Regards, Ehsan Fareed |
November 30, 2009, 13:56 |
Ehsan Fareed
C'mon anyone....................????
March 22, 2015, 22:29 |
Ash
hello,
did you reach to any solution because even I am stuck with the same problem of "no buuble formation" (stratified flow). |
Multiphase model, water disperses in air | bugra | Main CFD Forum | 1 | January 30, 2010 10:57 |
multiphase model, water in air? | bugra | Main CFD Forum | 10 | January 2, 2010 13:09 |
Help needed in 3D multiphase micro model | ehsanfareed | FLOW-3D | 1 | November 29, 2009 19:07 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
air and water vapour mixture - multiphase model | Saba | FLUENT | 0 | February 10, 2009 12:05 |
