November 25, 2009, 07:35 |
Shadow Wall / Help Sought
sateesh
I have two adjacent zones one is solid (coal) and another one is fluid (Occupaid by Oxygen). A reaction is taking place at the solid surface/interface i.e. coal is getting combusted with oxygen (which is coming from the fluid zone). It is a exothermic reaction. because of this reaction, heat transfer 'll takes place in both the zines. I need to obtain the temperature profile in side the two zones. I need to create a geometry in a way that only heat should get transfer through the interface between the two zones. How can i create the shadow wall for on side interface? or can any body suggest me how can i solve this problem in FLUENT? Thanks in Advance |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
wall shadow problem | paul | FLUENT | 5 | November 16, 2013 13:46 |
wall shadow | amar | FLUENT | 1 | February 5, 2010 06:07 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
