December 12, 2009, 10:01 |
What depth does fluent use in 2D problems?
thanos
Hello engineers,
I try to simulate the flow in a duct. As inlet boundary condition i choose the velocity inlet and as outlet the outflow. When i take the solution the mass flow result differs from this that i calculate with my pencil. I found out that in 2D problems fluent in order to calculate the mass flow rate regards the 2D geometry as a plate 1m deep. However, i want to have a cylindrical duct simulated and not a quadrangular one! What can i do to change this option? I have not find a solution to this yet. Thank you in advance! |
December 14, 2009, 04:05 |
Max
Hi Thanos,
for axisymmetric problems ( i guess your pipe is so) use the axi-symmetrical solver in Fluent. Using the cartesian 2-D solver will give incorrect results independant of the depth defined. cheers |
December 14, 2009, 04:14 |
thanos
Hello coglione!
Actually, my problem is not axisymetric. It is a T-junction of two ducts. is there any option to help me or i have to run a 3-D simulation for sure? With respect |
January 11, 2010, 03:24 |
YH Tan
Thanos,
I think u need to run it 3D. 2D simulation will give u the depth of 1 unit of the unit u use. If u use meter, u get 1 meter depth. even worst is, its not representing round. I guess doing 3D won't take u alot of time. unless ur flow is very complex.
Herntan, Add Reputation if I am right |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Fluent Convergence Problems | Vidya | FLUENT | 24 | January 1, 2016 13:01 |
Fluent connection with simulink by TCP/IP | Tanktruck | Fluent UDF and Scheme Programming | 1 | June 28, 2009 12:56 |
Problems with the UDF in Fluent | Mathew | FLUENT | 1 | February 26, 2008 19:15 |
Problems with Fluent | Jacek | Main CFD Forum | 2 | August 16, 2002 04:14 |
