HELP!a problem when starting the unsteady iteration in Fluent |
January 19, 2010, 08:56 |
xuusst
I have a problem when starting the unsteady iteration in Fluent,and it said——"warning:non-positive volumes exist.
Error:divergence detected in AMG solver ressure correction Error object) I guess something wrong with my original grid in Gambit? hELP ME!THANK YOU! |
January 20, 2010, 12:41 |
Raditya Wiranegara
You might to reconsider your meshing result from GAMBIT. Check your mesh result. Have a look on your right corner of your GAMBIT window to this. The 'non-positive volume' exist due to the highly-generated skewness.
As for the divergence problem,you can prevent this by setting your 'under-relaxation factor'. Make it smaller. Hope this short reply would solve your problems. Regards, Raditya |
January 21, 2010, 01:37 |
xuusst
Thank you for your kind advice,Raditya
Yes,the blade in my model has a very high skewness,so I 'm trying to use the Boundary Layer or Sizefunction to make a better mesh |
Problem with Fluent Parallel | DarrenC | ANSYS | 0 | October 27, 2009 05:38 |
Fluent dpm (unsteady) problem! Urgent! | Aris Nikolopoulos | FLUENT | 0 | January 17, 2008 07:54 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
Problem in Reporting Unsteady Particle Fates | Nelson | FLUENT | 0 | August 23, 2006 20:24 |
starting fluent under freeBSD4.9 | Herakles | FLUENT | 0 | June 2, 2004 09:05 |
