inlet manifold
Old   January 27, 2010, 09:33
Default inlet manifold
renu is on a distinguished road
Hello friends,
I am simulating diesel engine inlet manifold.
For this i am using velocity inlet for inlets and pressure outlets for outlets.
For transient boundary conditions i am using transient profiles.In this there are negative pressures.In operation conditions i changed pressure to zero.To use absolute pressures.
But the problem is one of the outlet is changing to inlet and revers flows are occurring on the so many faces of outlets.When i am using gauge pressures the outlet remaining outlet.
So please give me suggestions to overcome this problem.
please....
Thanks in advance.
renu is offline   Reply With Quote
Old   January 27, 2010, 22:11
herntan's Avatar
YH Tan
herntan is on a distinguished road
hard to imagine what u trying to say. can u post picture with explaination?
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   January 28, 2010, 01:08
mas
Mas
mas is on a distinguished road
Setting the pressure operating condition to zero is a very bad move, the way fluent solver sees it. Try setting it back to atmospheric. I'm sure you should be able to overcome the problem.
<Mas>
mas is offline   Reply With Quote
Old   February 1, 2010, 11:56
Thanks for u r replay,
I changed the operating pressure to 101325pas, and changed the operating pressures in to guage pressures.But still iam getting the same results.
Means the outlet is becoming in to inlet and reverse flows occurring on so many boundary faces.
Iam unable to find for what resons these reverse flows are occurening.
and why the outlet is changing in to inlet.
please give me some idea for what resones these are occurring.
thanks in advance.
Old   February 2, 2010, 01:56
-mAx-'s Avatar
Maxime Perelli
your outlet-BC cannot switch to inlet-BC without you have specified it.
Check your massfow at inlet and outlet, the imbalance should be 0, and the massflow at your outlet should be negative.
If not, then you have a problem
Reversed flow can occure (for instance vortex accross the outlet)
Old   February 2, 2010, 05:31
Thanks for u r quick replay max,
I check the mass flow the imbalance it is 0. But one of the outlet have the positive value.
In the time of running solution reverse flows are occurring on outlets.So I think due to this the outlet is changing in to inlet is am correct.
so how can i avoid this problem.Means what the reasons for my problem am not getting.
Please give me suggestions on this matter.
thanks in advance.
Old   February 2, 2010, 06:37
-mAx-'s Avatar
Maxime Perelli
If your mass imbalance is 0, but one of your outlet has negative value, it is weird.
How is the pressure distribution in your model? (realistic?)
What kind of BC did you set at your inlet?
Old   February 2, 2010, 07:16
pressure distribution is realistic and velocity inlet is the BC.
Old   February 2, 2010, 08:00
-mAx-'s Avatar
Maxime Perelli
post a picture with your pressure ditribution and also velocity distribution
Old   February 2, 2010, 08:55
uday
uday is on a distinguished road
aggfjjhjllljljljl
uday is offline   Reply With Quote
Old   February 2, 2010, 09:02
Pressure and velocity distributons
Old   February 2, 2010, 09:28
-mAx-'s Avatar
Maxime Perelli
Your geometry seems to be symetrical, if your BC are alson symetrical, you can split your domain and compute one half.
Your outles are quite close to T-junction. For sure they are in a recirculation zone.
I would extend the outlets.
Old   February 2, 2010, 09:48
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Send me the geometry and BC... I'll try to make a parallel calculation to your...
Philipov is offline   Reply With Quote
Old   February 2, 2010, 10:19
Give me u r mail id i will send geometry and BC to u r mail.
Old   February 2, 2010, 13:50
Philipov's Avatar
Svetlin Filipov
svetlin.philipov@gmail.com
Old   February 3, 2010, 03:34
uday
qedfgdsfwff
Old   February 5, 2010, 07:29
Wink ejector
  #17
bgu
bgu is on a distinguished road
renu, Judging from the pictures, the right hand outlet is nearly opposite the inlet, whereas the left one is offside. Looks to me that the left hand outlet is actually an ejector and I would guess that this is the one with the reverse flow.
bgu is offline   Reply With Quote
Old   February 5, 2010, 10:48
uday
Thanku for u r replay,
I didn't understand how to overcome this problem.Can u give me any suggestions. Actually at outlets there are suction pressures also.I think thats why these reverse flows are occurring.
Is the suction pressures are reasons for the reverse flows then how would i overcome this problem.
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
transitional inlet boundary condition kamp CFX 1 June 21, 2006 11:08
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 07:37
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
