February 3, 2010, 14:09 |
Fluent animations
Rob
I'm working on the flow around a cylinder in 2D and was wondering if anyone knew how to plot and save the dynamic pressure and velocity around the cylinder so i can make an animation using the images?
February 3, 2010, 21:53 |
Mas
Rep Power: 16 |
Use Execute Command
eg. /di/sw 1 /di/cont/pressure /di/hc pressure%t.tiff
<Mas> |
February 4, 2010, 02:43 |
Svetlin Filipov
Rep Power: 17 |
First must define case and data file saving (let's say each timestep).... after that read case and data files in Tecplot... there you can make a good animation
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
Fluent Animations | AndyC | FLUENT | 3 | July 13, 2007 09:01 |
