help with natural convection
Old   February 18, 2010, 17:54
Default help with natural convection
Eric
cloudnqh is on a distinguished road
I'm doing a natural convection modeling for the flow and radiation inside a container. The air pressure inside the container is very low, e.g. 30 tor. It seems that I can not use the boussinesq model because beta*(T-T0)=5>1. What should I use to model the natural convection?
I have two thoughts which need your help:
(1) Define density as a function of temperature?
If I define the density as a function of temperature, how to define the operating pressure and operating density? What I did is to set the operating pressure as 30 tor and set the operating density of the air under 30 tor. Also I calculated the density under 30 tor and different temperatures. But I got divergency error. Please tell me if this method is not good.
Or (2) choose the imcompressible ideal gas model?
The operating pressure is very low and container internal hot surface temperature Th is very high, does that mean I can use the imcompressible ideal gas model?
Thanks a lot for your help!
Eric
cloudnqh is offline   Reply With Quote
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
Mixing By Natural Convection Processes Greg Perkins FLUENT 0 February 12, 2003 18:40
natural convection in a sealed enclosure James Main CFD Forum 4 April 2, 2001 15:48
