How to simulate a wire-screen (mesh) in 3D ?
Old   May 18, 2011, 09:42
Default How to simulate a wire-screen (mesh) in 3D ?
Sangram Roy
sangramroy is on a distinguished road
hi,
I want to simulate a wire screen in 3D. The wire-screen (mesh) is to be used as a liquid-solid (water-glass beads) separator in fluidization. Following are the properties of the glass beads
Size (dp)= 1.36 mm
Density = 2468 kg/m3.
The wire-screen should allow only water to pass through it and prevent the flow of glass beads through it. I tried with porous boundary condition available in Fluent. But because of two-phase flow, I suppose,resistances of each phase needs to be calculated. Moreover, Eulerian-Eulerian approach is being used to simulate.My queries are:
i) How do I do the meshing and what boundary conditions is to be used?
ii) How do predict/calculate the resistances for porous boundary condition such it allows only one of the phases (water) to pass through it?
sangramroy is offline   Reply With Quote
eulerian multiphase model, porous modellling
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
How simulate a fine screen McClaud CFX 3 March 12, 2009 16:25
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
