February 18, 2010, 09:44 |
negative volume error
Amrit
Rep Power: 16 |
while iterating a case of dynamic meshing, using FLUENT 6.2.16, i got a "negative volume error"... can ne1 plz tell me the various possibilities for the above mentioned error..plzz help..... thank you!!!
February 19, 2010, 01:14 |
Maxime Perelli
Rep Power: 41 |
Investigate the reason for negative volume.
Typically it is a MDM parameter issue. It can ba also due to a high time step. Did you check your mesh motion?
In memory of my friend Hervé: CFD engineer & freerider |
February 20, 2010, 00:20 |
Amrit
Rep Power: 16 |
yeah..i checked mesh motion... it worked out well with 0.00005 s as time step bt showed the error when i increased the time step to about 0.007s... may b its due to "time step" in my case... thanks a lot...
February 25, 2010, 12:26 |
Rep Power: 16 |
the minimum negative volume is due to grid generation
any grid had this message when you check it, the calculation don't start return to gmabit and verify the mesh first |
February 26, 2010, 01:07 |
Maxime Perelli
Rep Power: 41 |
No correlation with Gambit
February 26, 2010, 01:08 |
#6 | |
Maxime Perelli
Rep Power: 41 |
So it is a MDM issue, and it should be solved within Fluent. Gambit has nothing to do with Remeshing stuffs (Moving mesh)
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; February 26, 2010 at 01:15. Reason: explanation |
negative volume error |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
solve negative volume error | sravan | Main CFD Forum | 1 | September 26, 2007 21:57 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
