UDF: How to use Macro C_VOF()
Like Tree2Likes
  • 2 Post By mohsen zendehbad
Old   July 15, 2008, 04:08
Default UDF: How to use Macro C_VOF()
Sam
Hi, every one:
I have defined a 2D immiscible liquid-liquid flow flied in a square box. I used the VOF model. I wanna identify the interface between the two liquids, so I used the following code to identify the interface:
cell_t c; Thread *t;
begin_c_loop(c,t) {
real vof;
vof=C_VOF(c,t);
if (vof>0.&& vof<1.)
However, when the UDF load to the fluent and iterating, there were errors
ACESS_VIOLATION
So I doubt that the using of the C_VOF has limitation. Could anyone who konws about this? Thank you very much!!
Old   March 3, 2010, 07:30
MOHSEN Zendehbad
mohsen zendehbad is on a distinguished road
you should first access the sub thread related to that phase, you should put that thread as an input of your C_VOF(), find the function THREAD_SUB_THREADS() in fluent documentation.
utkunun and Santiago2015 like this.
mohsen zendehbad is offline   Reply With Quote
Old   March 3, 2010, 08:49
Bernhard
Bernhard is on a distinguished road
Why don't create an iso-surface of your vof variable with value 0.5, then there is no need for using an UDF.
Bernhard is offline   Reply With Quote
load sheme macro (Solv Execute Command macro) manu FLUENT 2 March 13, 2008 01:00
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
error in udf, C_VOF paulina FLUENT 0 April 16, 2004 09:29
error in udf, C_VOF paulina FLUENT 0 April 16, 2004 09:27
UDF{ C_VOF(c,pt[n]) } two phase flow ROOZBEH FLUENT 2 April 21, 2003 04:09
