Micro-channel flow not converging
Old   March 19, 2010, 02:29
Default Micro-channel flow not converging
esgee is on a distinguished road
I am currently simulating 3D water flow in 0.1mm x 1mm channel and a larger cylindrical container. I have tried several different meshes but none of results are converging, the velocity residuals are levelling off at ~1e-2 and the continuity residual is at ~1e-1 or ~1e-8.
The volume of smallest cells is very low, ~1e-12 m^3, can that cause some round-off error or loss some significant numbers or something else that the result won't converge? The number of cells is ~1e6
The only data I know is the mass flow rate at the inflow. My boundary conditions are "mass flow inlet" and "outflow" (I can with high certainty say that the flow is fully developed at the outflow). I'm having difficulties to determine operating pressure and its location. Also, should gravity be involved?
esgee is offline   Reply With Quote
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 07:34
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
VOF scheme for open channel flow yan FLUENT 1 May 21, 2005 00:21
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
