SI engine tutorial error non-positive volumes
Old   March 24, 2010, 13:49
Default SI engine tutorial error non-positive volumes
rackem is on a distinguished road
While going through the SI engine tutorial I encounter an error when trying to preview the mesh. At around crank angle 570 an error comes up mentioning the negative volume and cuts the preview. When I run the check mesh, it comes up with a couple warnings....
Volume statistics:
Warning: non-positive volumes exist.
minimum volume (m3): -5.334022e-022
maximum volume (m3): 3.089859e-006
total volume (m3): 9.300594e-003
Checking face handedness.
WARNING: left-handed faces detected on zone 41: 3491 right-handed, 2 left-handed.
WARNING: left-handed faces detected on zone 29: 5 right-handed, 2 left-handed.
I followed the tutorial as close as I could up to that point and am not sure where the problem may be from.
The tutorial can be downloaded from this location
http://www.fluent.com/software/sf_me..._si_engine.htm
Thank you
__________________________________________________ ________________________________________________
EDIT: In the transition from the Fluent 6 tutorial to Fluent 12 I missed a simple step that wasn't clear and that was checking the region face box in the remeshing methods option
rackem is offline   Reply With Quote
Old   March 28, 2010, 23:25
李逾
yubaibai88 is on a distinguished road
I meet the same problem...maybe we should try little time steps,for example set the Crank Angle Time Step to 0.1 in dynamic mesh parameters\in cylinder
yubaibai88 is offline   Reply With Quote
Old   March 31, 2010, 15:08
were you able to run this correctly? I run into problems when the simulation starts the spray injection and the program freezes.
Old   March 31, 2010, 22:40
李逾
I found it unable to process whe start mesh motion in order to preview the dynamic mesh. it appears negetive volume
Old   March 31, 2010, 23:06
I fixed this by checking the region face box in the remeshing methods options in the dynamic mesh settings.
Old   April 2, 2010, 23:19
李逾
hi:
I follow all the tutorial tell me to do.but I found the same problem when the simulation starts the spray and the program freeze.did you find how to solve it?
thanks in advance
Old   April 7, 2010, 19:19
No I have not found a way around this
Old   April 8, 2010, 21:23
李逾
hi rackem:
when I disable "track with fluid flow time step" in define->model->discrete phase->particle treatment,the simulation go down to the end.
have a try,hope it help
Old   April 9, 2010, 12:25
My solution still stops at injection. What does your discrete phase model look like. Right now I have Interaction with Continuous Phase and Update DPM Sources Every Flow Iteration checked in the Interaction box. (Note I can't change the Number of Continuous Phase Iterations per DPM Iteration to 5 as it is grayed out and has to be 200) In Particle Treatment I have Unsteady Particle Tracking checked and the Particle Time Step Size (s) at 0.001 (Note the Number of Time Steps is grayed out and listed at 1). In Inject Particles at I have Particle Time Step selected instead of Fluid Flow Time Step. In Physical Models I have Droplet Collision and Droplet Breakup selected in the Spray Model. TAB as the Breakup Model. y0=0 and 2 Breakup Parcels in Breakup Constants.
Thanks for the help!
Old   April 9, 2010, 21:32
李逾
hi
here is my panel.
obey all the process tutorial tells us to do.
try!
Old   April 14, 2010, 17:14
I've obeyed all the processes, but still get it freezes at injection. You do not follow the tutorial because you do not have "Update DPM Sources Every Flow Iteration" checked per your image that you posted. So I'm not sure which rules to follow in the tutorial.
What do you have checked in the "physical models" tab in the Discrete Phase Model?
When I check Droplet Collision in the Discrete Phase Model/Physical Models tab it changes my "Number of Continuous Phase Iterations per DPM Iteration" back to 200 and grays it out.
What version of Fluent are you using? I'm using 12.0.1
Old   April 14, 2010, 20:07
李逾
my version is 6.2.26
Old   November 22, 2010, 08:06
ZenCef
ZenCef is on a distinguished road
Is there any solution ?
ZenCef is offline   Reply With Quote
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 19:44
Fluent SI engine tutorial problem Jonny6001 FLUENT 4 January 22, 2012 19:26
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 05:05
Tutorial 13 Internal Combustion Engine Wei Siemens 11 March 6, 2009 06:24
non positive volumes pankaj shukla FLUENT 4 December 6, 1999 09:42
