March 29, 2010, 18:31 |
Turbulence Model Problems
Luke
Hello All
I'm having a problem on Fluent when I switch from k-e r to a k-w sst model. When I used the k-e model I had no problems and I obtained a solution fine. Now that Ive changed to the k-w sst my solution keeps diverging although everything else is kept the same from the previous model. Any ideas of why this is and how to solve it? Thanks for your help |
March 30, 2010, 02:02 |
Svetlin Filipov
turbulent models must be chosen according to the flow type. The mesh need to be changed too...
April 8, 2010, 04:54 |
heidar
heidar jafarizadeh
in fluent the K-w turbulence model uses one eqution model to resolve the flow structure near wall. whereas the K-e model can uses the 3 type of near waal solution. using one eqution model for near wall treatments leads us to beter results but u have to increase the mesh density.
ok go on and increase mesh density but be care that now u could not compaire the two answer of K-e and K-w. bye |
May 3, 2010, 04:26 |
Yplus
ali
Check values of yplus ....
If you have seperated flow try SST but be sure to have low yPLUS ~1 (i guess). SST uses kw in near wall and ke in inner region .... In case you dont have seperation better use ke , computationally good Regards Ali |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Implementing and running a new turbulence model | svens | OpenFOAM | 3 | August 21, 2009 02:59 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
