February 24, 2010, 12:54 |
divergence detected in AMG solver ?
Rep Power: 16 |
Hi everyone,
in some cases that I have runned before, the case started normally to converge and suddenly it stoped writing the message: divergence detected in AMG solver: pressure what this the reason and where is the problem ? who should I process to solve that thanks |
March 23, 2010, 07:00 |
divergence detected in AMG solver: pressure correction
Srikrishna
Rep Power: 16 |
Hi all,
I am encountering this error when I compute my problem divergence detected in AMG solver: pressure correction My problem is 3D, supersonic (Mach=2.49); Flow over a conical probe; structured mesh; I first used Spalart Almaras model for turbulence; it gave me the divergence error; So i used k epsilon; again I get the same error; I declared all the outer boundary to be pressure far field; So there is no pressure outlet or velocity inlet as such; The flow is compressible; unsteady In the materials window; can I use viscosity to be constant; i used ideal gas for density; Please let me know how to get rid of this error. Reply asap!! Thanks. |
March 25, 2010, 19:47 |
karine
Rep Power: 16 |
Hi
are u using steady or unsteady solver ? |
March 25, 2010, 21:05 |
divergence amg solver
Srikrishna
Rep Power: 16 |
unsteady solver; spalart almaras model; five stage runge kutta time stepping scheme
March 26, 2010, 02:51 |
karine
Rep Power: 16 |
u can try to change ure pressure interpolation scheme. This can help.
However, the best way to avoid this is to reduce ure time step and to Reduce also the under-relaxation factors , specially if u have a transitional case ( iwhen u get a steady state, u can tolerate bigger time step, but this is not ure case as ure flow is supersonic). If u care for precision, use more than one iteration by time step (as u reduce under-relaxation factors, the solution will converge more slowly): monitor data so u can estimate the number of iterations by time-step that u need. Dont forget to ative the autosave command, so in ase that ure solution diverge, u dont loose everything. |
March 26, 2010, 14:20 |
autosave command
Srikrishna
Rep Power: 16 |
thank you very much for the help. I will try doin that; but please tell me how to activate the autosave command; if i do this, then how does fluent know how often to save the computation. let me knoe kindly!
Thanks. |
March 26, 2010, 18:45 |
karine
Rep Power: 16 |
Hi again
File--->write--->autosave then u can choose saving frequency Regards |
March 26, 2010, 19:08 |
Srikrishna
Rep Power: 16 |
Thanks you very much. So the frequency parameter determines how many seconds for which the computation has been saved.
I hope I am right! Let me know. Thanks. |
March 27, 2010, 07:07 |
#9 |
karine
Rep Power: 16 |
yes
if u dont change simulation parameters, u just need to save data files (without case files) |
March 27, 2010, 07:14 |
#10 |
Srikrishna
Rep Power: 16 |
Thanks. I got you.
March 29, 2010, 16:57 |
#11 |
Srikrishna
Rep Power: 16 |
I am modeling supersonic flow over a probe. I am using the axis boundary condition in gambit for my axisymmetric model. In the original 3D model, the outer boundaries were all pressure far field.
Can anyone please tell how I must declare the boundaries. Geometry: Half cone+cylinder arrangement There is some initial clearance before the cone nose for simulating the flow from infinity. Please let me know asap so that I can proceed with the work. Can I upload any picture of my geometry. If so kindly let me know Thanks. |
divergence amg |
Display Modes | |
Divergence detected in AMG solver: pressure correction | jimmer | FLUENT | 2 | August 7, 2010 07:47 |
Error: divergence detected in AMG solver: temperat | Rubén | FLUENT | 3 | December 11, 2007 12:48 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
error: divergence detected in AMG solver | sharuk | FLUENT | 2 | July 21, 2005 09:03 |
