change particle properties using udf?
Old   April 1, 2010, 15:12
Default change particle properties using udf?
ljp
ljp is on a distinguished road
HI all,
In modeling particle spraying, I try to change some of the particle's properties during flight when certain conditions are met. I wrote a udf using DEFINE_DPM_PROPERTY as in the example shown in the udf manual, but then found out that in the dialogue box for setting particle material, only a few properties allow udf (i.e. have the "user-defined function" option in the drop-down list), and others (like the thermal conductivity) do not have this option. So if I need to change the particle's thermal conductivity, what should I do?
thanks in advance!
ljp
ljp is offline   Reply With Quote
Using UDF to alter particle size Tumppi Fluent UDF and Scheme Programming 7 February 28, 2019 08:27
Add Mass to a Particle with UDF (DPM) sega Fluent UDF and Scheme Programming 6 October 24, 2013 22:14
Problem with getting the particle position using UDF Ananth Pai FLUENT 0 January 17, 2010 01:11
HELP! HELP! For udf of particle body force!!!! zhaoh FLUENT 0 February 5, 2007 04:10
Problem in UDF about particle size distribution fpingqian FLUENT 0 February 25, 2005 01:48
