April 3, 2010, 00:36 |
compressible flow through a pipe
Rajiv Kumar
Hi
I am trying to find a cold flow profile through a pipe. I have pipe of 1340 mm length and injecting oxygen at 6 bar from one end through a hole diameter of 5mm and exit diameter is 14mm. The problem i am facing is that when I am solving for compressible gas using ideal gas in material and energy equation. The solution always diverges. The boundary condition I gave for inlet is mass flow inlet and for exit is pressure outlet where I specify target mass flow as it is know to me. can you please help me find reason why it diverges the solution. thanks rajiv |
flow, pipe |
Incompressible and compressible flow. | Confused student. | Main CFD Forum | 27 | March 18, 2017 12:25 |
compressible flow computation | amv | Main CFD Forum | 5 | June 27, 2003 07:27 |
stepped pipe flow | Tom Cloutier | Main CFD Forum | 0 | April 20, 2003 13:19 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
