interfacial shear stress
Old   April 10, 2010, 23:05
Default interfacial shear stress
Eric
duaiduaihu is on a distinguished road
my work is focused on the water-oil stratified flow.
as the interfacial is curved and the shear stress must be tangent to the interface, it is a little difficult fo me to get the interfacial shear stress in the flowing direction per unit length .
your reply will help me out. hoping for everyone's reply! Thanks
duaiduaihu is offline   Reply With Quote
Old   April 11, 2010, 11:58
Jouke de Baar
jack1980 is on a distinguished road
Perhaps you can try the following. Assuming your running a VOF method.
Surface -> Iso-Surface ...
Surface of Constant: Phases ... Volume Fraction
Iso-Values: 0.5
From Zones: fluid
New Surface Name: interface (or whatever you like...)
Display -> Countours
Contours of: Derivatives ... Strain Rate
Surfaces: interface
(perhaps you will have to turn of Auto Range and enter a proper Min and Max)
The shear stress should simply be related to this strain rate by the viscosity. Although I can't figure out which viscosity you should use here, since the phase is "mixture". A quick solution might be to - temporarily - adjus both viscosities under Define -> Materials ...
Anyway, you would have to look into this shear-stress / strain-rate relation.
Hope this helps, good luck!
jack1980 is offline   Reply With Quote
Old   April 12, 2010, 04:21
Eric
Originally Posted by jack1980 View Post
Iso-Values: 0.5
From Zones: fluid
Surfaces: interface
hi ack1980!
Thanks for you reply!This will help me a lot!
what I want to know more is the integration of the shear stress of the interface(the dotted line )in the X direction.we can get the shear stress of each cell, but how to get the direction of the shear stress, as it is different of the shear stress direction of each cell, how to get the integration of the shear stress alone the interface(the dotted line)in the X direction. I think UDF might be used.
Hoping for your reply! thanks..
Old   April 12, 2010, 04:39
Jouke de Baar
I'm afraid the image is unavailable
Old   April 14, 2010, 03:44
Eric
hi jack1980,thanks for your kindness.would you please tell me your email address.it would be convenient for me to describe my problem clear!
my email address is daozhenxu@hotmail.com
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
How to get shear stress all over the flow domain lingo FLUENT 2 November 3, 2003 21:16
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
WALL SHEAR STRESS Min-Hua Wang CFX 0 April 3, 2002 17:40
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
