March 31, 2012, 17:02 |
impeller motion in an open raceway pond
Hossein
Rep Power: 15 |
Dear all
I am using Fluent 6.3 to simulate a 3D impeller in an open raceway pond for microalgae culturing (you can see the picutres by simple search in google); I have done these steps in creating the model in Gambit: 1- whole channel creation 2- a cylinder indicating as the moving mesh area 3- subracting the cylinder from the whole model (retaining the cylinder) 4- creating the impeller 5- subracting the impeller (without retaining the impeller) I devided the whole model to two areas: down=water and up=air zones: up (air) & down(water) & the cylinder including the impeller===>fluid B.Cs: the two sides and the surface of the inner cylinder: interface the two sides and the sufrace of the outer cylinder (the cylinder wich is the result of the volume subtraction): interface in Fluent, I connected the two interface areas with "Grid interface" water and air zones are stationary and the cylinder is moving mesh the problem is when the cylinder rotates, the water inside the cylinder doesn't mix with the water in the channel. I know that all other things are ok; like the VOF, patching, .... Is there any suggestions? my email address: hossein.amini.che@gmail.com |
April 10, 2012, 14:22 |
Maxime Perelli
Rep Power: 41 |
can you post a sketch of your model, and color the differents parts for better understanding.
But I can say that if you want a moving cylinder (with rotation) in your domain, you may disconnect your cylinder from the other domain (else the sliding mesh won't work)
In memory of my friend Hervé: CFD engineer & freerider |
April 10, 2012, 17:08 |
Hossein
Rep Power: 15 |
This is it;
I should notice that the 3 volumes are seperate, but st. zone1 and zone2 are connected. The boundary conditions are: 1- for the moving mesh, I have chosen the whole cylinder as an interface 2- for the cylinder just inside the channel also interface that fluent seperates the interfaces automatically as it belongs to two different zones. all zones are set to fluid
Hossein Amini PhD student in Biochemical Engineering; Computational Science and Engineering department; North Carolina Agricultural and Technical State University |
April 10, 2012, 17:10 |
Hossein
Rep Power: 15 |
I forgot to mention, I want the impeller inside the cylinder operate as an agitator, that's what I desire. I don't care what happens to the cylinder. (I mean the motion of the impeller is important. that's why I have set the boundary surfaces as interface)
April 11, 2012, 03:55 |
Hossein
Rep Power: 15 |
This is the figure of interface boundary condition I have set. this boundary condition also has been done for the cylinder inside the channel. Then, in FLUENT, I connect the two interfaces with "grid interface".
April 11, 2012, 04:07 |
Maxime Perelli
Rep Power: 41 |
you have to increase complexity of your model step by step.
I don't understand where comes fluid in. Any way First concentrate you on the sliding mesh. What is the surface (white) which is in the middle of your domain, but not splitting the whole domain? Then if you only have your red mixer which is rotating, forget stationnary etc... you only have to work with interfaces. Define the red generated surface as interface 1 and the white generated surface as interface 2. Define the red rotating volume as separated fluid domain, for being able later to define it as rigid body in Fluent When moving back your rotating (red) volume, then interface 1 and interface 2 should be superposed. Only connect them back in Fluent by defining grid interfaces. Once your mesh is well rotating, and fluid isn't stopped at interfaces, then introduce vof
April 11, 2012, 07:10 |
Hossein
Rep Power: 15 |
let me be more anal about the model:
1- there is no fluid inlet. So, imagine a pool (elliptic shape) which has a height of 0.5m and filled with water up to 0.2m. There is an impeller which circulates the water inside the pool (this is the definition of the geometry of an open raceway pond for microalgae culturing) 2- the white surface inside the pool is just a wall for dividing the pool to have a circular characteristic (you can see it in the real model below). after these all, I should tell you that I do know that I have to use VOF, I have seperated the mixer domain and the channel domain as fluid zones (in which mixer is as a moving mesh not stationary). I know that I have to use grid interface in FLUENT to connect the two zones (stationaries(air and water) and moving(mixer)) but after setting these all , I got a problem with the phase transformation between two zones. you know, the mixer zone acts like there is no connection between the mixer and the channel and all of the cylinder around the mixer has a role like WALL boundary conditions. So the mixer can't mix the whole water in the channel
April 11, 2012, 07:19 |
Hossein
Rep Power: 15 |
here is a real model of what I am going to simulate
moving mesh, open channel, open raceway pond, paddle wheel, vof modeling |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
