error iteration in FLUENT--difficult to take data
Old   April 14, 2010, 22:20
Red face error iteration in FLUENT--difficult to take data
rosalina is on a distinguished road
i have a model that consist of few volume in GAMBIT..while i mesh it all at once by Tet/Hybrid-TGrid, it was not completed..so I split the volumes and mesh one by one by mesh volume Tet/Hybrid-TGrid..
While running at FLUENT, error floating number shown..and the ENERGY LINE of the residual is about 10e+22..what a big number, so it wasn't convergent till now..
what should I do to make the convergence faster to take the data?
what was the problems actually?
Thank you..
rosalina is offline   Reply With Quote
Old   April 14, 2010, 23:01
Chris
Chris D is on a distinguished road
If your energy residual is that large, then you definitely have not converged the problem. Without knowing anything else, I would start by checking your grid, because you mentioned that you had trouble generating it in the first place. A few things to check:
Make sure your geometry doesn't have any sharp edges. An infinitely sharp edge is non-physical, and could blow out your solution.
Make sure you don't have highly skewed elements in a region of large flow gradients (i.e., boundary layers.)
Make sure you don't have a rapid change in cell volume from one cell to the next. This can also blow out you solution.
To get more help, you might want to provide more information about what your doing. Pictures are always good!
Chris D is offline   Reply With Quote
Old   April 14, 2010, 23:53
thank you for your prompt reply...
actually,yes..I have seen comment about highly skewed elements when i mesh my object..but truly I don't really know about what was that mean..
my object is a reactor tank which consist of 116 cylinder of fuel on it..the initial problem is the grid of fuel always not completed, so i split the tank volume and fuels volumes..then i mesh it separately by mesh volume..when it works, if i'm not mistaken, comment about highly skewed elements shown..
[IMG]file:///C:/Users/Oca/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Oca/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Old   April 15, 2010, 01:11
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
* highly skewed elements can provide convergence issue.
* disable energy equations and re-iterate. Just to be sure that your problem doesn't come from your thermal's set-up.
Anyway I would go back to gambit and check how many cells do you have with skewness > 0.9
Then correct your mesh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 15, 2010, 02:27
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Hi rosalina,
do you want me to try meshing your model?
Philipov is offline   Reply With Quote
Old   April 15, 2010, 08:52
i choose the energy equations because i want to insert thermal parameter in the boundary condition..can i do your suggestion while the thermal parameter was i inserted and still running the iteration?
Old   April 15, 2010, 08:55
Originally Posted by Philipov View Post
Hi rosalina,
are you serious?how could it be then?
Old   April 15, 2010, 09:07
-mAx-'s Avatar
Maxime Perelli
You have to restart your computation
Go to define/models/energy and disable energy.
Then initialize and iterate.
Old   April 16, 2010, 01:58
Philipov's Avatar
Svetlin Filipov
send the model to my e-mail
Old   April 18, 2010, 22:09
if i would take the data of temperature (later when it was already converged)while the energy equation is disable..can i?
Old   April 19, 2010, 01:51
-mAx-'s Avatar
Maxime Perelli
This trick is just to dismiss your energy's set-up as source of error.
If you don't get problem anymore while disabling energy equation, then your problem comes from there.
You are in debugging phasis: once you find the source of your problem, you may re-compute your model properly.
It doesn't cost lot's of effort... just disabling energy model and re-iterate: either you don't have problem anymore, and you know that something is going wrong with your energy set-up, or you still have the problem, and you have to find in another direction (like you mesh for instance)
Old   April 19, 2010, 22:57
yap..seems my problems came from "energy"..i've done your suggestion, and not for long time iteration..it converged..but i couldn't get the temperature data..when i enable again the energy equation and initialize..i should iterate again to have the temperature data right?
Old   April 19, 2010, 23:21
still trying attach my file to your e-mail..by the way, thank you in advanced..
Old   April 20, 2010, 00:46
-mAx-'s Avatar
Maxime Perelli
Then something isn't properly set in the problem set-up (energy)
In parallel a mesh without highly skewed cells would help
Old   April 21, 2010, 10:12
What was it means'and what should i try then?sorry, actually i am still in early stage learning CFD...by the way, do you knoe how and where i could get the spesific Fluent training?
Old   April 22, 2010, 00:59
-mAx-'s Avatar
Maxime Perelli
Check your parameters involved in the energy equation, also your BC
Tutorials are first step for self-learning
Conversion of Data file to FLUENT sanjibdsharma OpenFOAM Post-Processing 5 September 9, 2011 06:13
Importing Gambit data into Fluent Tyred ANSYS Meshing & Geometry 1 April 18, 2009 13:53
Data Transfer - Polyflow to Fluent to Abaqus Bob Carson FLUENT 0 March 27, 2007 09:31
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 17, 2007 23:24
data output from batch fluent run Wang FLUENT 4 March 11, 2005 11:01
