Mesh Compressible Flow around an Airfoil
Old   July 19, 2010, 12:28
Exclamation Mesh Compressible Flow around an Airfoil
Hector Antonio Alcalde Ludeña
hector is on a distinguished road
In these days I learn how to analyse the flow around an airfoil, but the model was inviscid. after that, I try to model a quite 'complex' model; I put K-epsilon turbulence model (I Don't change anything); Velocity equal to 300 m/s (5º Angle of attack), I activate Energy Ecuation, in material I define air as an ideal gas.
But when I try to run the model; I obtain this message:
Error: Divergence detected in AMG Solver: Temperature
Please try to help me with that.
Regards,
hector is offline   Reply With Quote
Old   July 19, 2010, 15:03
Chris
Chris D is on a distinguished road
How many iterations does it run before diverging?
Chris D is offline   Reply With Quote
Old   July 19, 2010, 23:58
Mmm I don't remember exactly but it happens iteration number 30 or 50; in this interval, after that appears the message
Old   July 21, 2010, 09:23
Chris
How good is the grid in the region where the solution is diverging? How are you initializing the solution? Have you tried reducing the courant number?
Old   July 21, 2010, 13:08
Hello Chris
In the file forward I show my grid; I Inizializate my solution in the zone called Farfield1, is in the front of the airfoil.
In the pictures, you can see how I make the analysis process in Fluent.
Thanks for your answers!
Old   July 21, 2010, 14:13
Chris
Originally Posted by hector View Post
Hello Chris
It looks like you're grid has vary large changes in cell volume, which definitely cause some stability problems. You want to make the grid such that the cell volume doesn't change too much from one cell to the next.
Also, you might think about switching to either the density-based solver or the pressure-based coupled solver for compressible flow.
Regarding the initialization, using fmg initialization gives a much better initial flowfield than initializing with a constant value. This reduces the chance that your solution will go unstable due to initial transients.
edit: I just noticed that you might be using an older version, so ignore what I said about density based and pressure based solvers.
Old   July 24, 2010, 00:59
Attachment 4153
Hello Chris
Sorry to be late in ask you in the picture forward is the correction that I made, Is much better like this?
thanks for your help, was really helpfull for me.
I have another question, why, when you analyze airfoils specially, you have to build this kind of mesh (as in the picture); why is not possible to mesh with a rectangle or another geometry?
Thanks for your time again
Old   July 26, 2010, 11:56
Chris
You can use other topologies to mesh the airfoil. See this link for a description of O and C grids. Also, you can use an O-H type topology, which I crudely sketched here.
Old   July 30, 2010, 13:59
Hello Chris
I can see your mesh styles alternatives, are interesting, I think you must have a better solution control in these ways.
I have another question, if I would like to model an unsteady flow event? (Transient event) such a Waterhammer? or maybe a wave propagation in a chanel, I heard that is possible to model in Ansys, but how I can enter the boundary conditions and also the equations to describe this transient event?
airfoil2d, compressible flow, fluent, mesh
Combined compressible flow and moving mesh with layers andersking OpenFOAM Running, Solving & CFD 4 March 1, 2011 09:40
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 13:16
Mesh size for particulate flow simulations Shahri Main CFD Forum 0 March 24, 2009 17:40
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
