How to specify an inlet boundary conditions for a fully developed gas flow in a duct.
Like Tree2Likes
  • 1 Post By legendyxg
  • 1 Post By leonardo.morita
Old   May 11, 2010, 04:08
Default How to specify an inlet boundary conditions for a fully developed gas flow in a duct.
Yang Xiaoguang
legendyxg is on a distinguished road
Dear everyone,
My model contains a rectangular duct with various kinds of gases flow through it. What I care is only the fully-developed region while I only know the mass flow rate. I found that if I specify the inlet boundary as a mass-flow-inlet type, the inlet region is not fully developed. So what kind of boundary type should I use in order to avoid the inlet developing length?
Thank you.
CFD_beginner12 likes this.
legendyxg is offline   Reply With Quote
Old   May 11, 2010, 05:30
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
If you want a fully developed flow at inlet, you should firstly run another simulation, in which you impose periodic conditions or you have a sufficiently long developing region. Once you obtain a developed flow at the outlet of this system, you can write a profile (Write > Profile) for your velocity and then read it in your final case (Read > Profile). When setting boundary conditions, you'll see that this profile will be available ("constant" tab). See FLUENT User's Guide chapter 4.6 for some more details.
leonardo.morita is offline   Reply With Quote
Old   May 11, 2010, 07:32
Yang Xiaoguang
I'll have a try and thanks for your help.
Boundary conditions for 2phase countercurrent flow rakib FLUENT 5 September 2, 2011 08:14
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 12:16
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Fully Developed Boundary Condition at Duct Inlet Twiti CFX 1 January 24, 2005 01:31
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
