Bulk mean fluid temperature in internal flow
Old   May 13, 2010, 15:56
Default Bulk mean fluid temperature in internal flow
Myeongsub Kim
mssound is on a distinguished road
Hi, how to calculate the mean bulk fluid temperature in channel flow in FLUENT? I have a hot spot at a specific location (therefore temperature profile in the channel will be different at different locations) and want to estimate convective heat transfer coefficient and Nusselt number.
The definition of mean bulk fluid temperature is
int(rho*c_v*U*T)dA / m_dot*c_v
Should I use UDF? If so, can anybody share the code with me? I'm really a beginner in UDF, so have no idea how to start to code.
I appreciate your helps.
MS
mssound is offline   Reply With Quote
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
[OpenFOAM] How to calculate the fluid flow through a surface lynx ParaView 4 January 20, 2016 11:58
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 14:05
stationary flow - transient temperature Nicola Siemens 5 June 16, 2003 05:44
Bulk flow of granular medium joel davison Main CFD Forum 3 November 1, 2001 10:47
