October 6, 2005, 22:50 |
Micromixing particle tracking
Hey everyone, I am trying to simulate mixing in microchannels by viewing the particle tracks in Fluent 6.2. I have read through all the tutorials on how to define the injection points etc.. When I run the simulation, it says that all the particles are either lost, or run incomplete. Is this because my mesh isn't fine enough or is there something obvious I'm missing because I am just too new to the program? Thanks for your time. ~Geoff
October 7, 2005, 10:51 |
Re: Micromixing particle tracking
I don't think your mesh size is a problem. Incomplete simply means that you're not tracking the particles long enough for them to leave your domain. Try increasing the the "Maximum number of steps" under the "Tracking" tab of the "Discrete Phase Panel" (see section 33.3.11).
Are the lost particles tracked at all? or are they lost at injection? If its the latter and your injecting at a wall boundary then try moving your injection away from the boundary slightly. I have also had problems before with lost particles when reloading case file but have not yet found the cause. Hope this helps Mark |
April 30, 2010, 14:37 |
Rep Power: 16 |
Hi
I'm working on T-micromixer and I want to simulate particle in this can u help me? thanks |
June 7, 2010, 16:51 |
T micromixing
constantinos kast
Rep Power: 15 |
to arashmarahel180
I would like, if you can, tell me that you introduced two different fluids in two entries had! if you do the experiment, please help me in this area. thanks |
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump | scatman | CFX | 7 | January 8, 2018 00:59 |
massless particle tracking problem | Renold | FLUENT | 0 | January 26, 2011 14:23 |
Particle Tracking for ion | Jun | CFX | 2 | August 31, 2010 08:19 |
Number density tracking rather than particle tracking | Rebecca | Main CFD Forum | 2 | April 23, 2009 12:52 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
