2D airfoil Cl and Cd are too high
Old   June 16, 2010, 09:12
Default 2D airfoil Cl and Cd are too high
Travis Moulding
travis.moulding is on a distinguished road
I知 new to CFD and I知 having a problem with Cl and Cd being too large. I知 running a steady state 2D airfoil with the following settings. I'm assuming there is a problem with the ref values but I have set them up the way I have read how to. Any thought would be great
General:
Density-Based, Steady
Models:
Energy On, Viscous- Realizable k-3, Enhanced Wall Fn
Farr field pressure, guage pressure 1525.647 (lb/ft^2)
Mach 0.6
Aoa 2 deg
Turbulence specification method K and Epsilon
Reference values: area 74.11in^2, depth 1in, length 74.11in
Solution method
Forulation: explicit
Flux type: Roe-FDS
Green-Gauss Node Based
Flow: Second Order Upwind
Turbulent Kinetic Energy: Second Order Upwind
Turbulent Dissipation Rate: Second Order Upwind
Solution Controls:
Courant Number: 1
Multigrid Level: 4
Residual Smoothing: Iterations = 0
Under-Relaxation Factors
Turbulent Kinetic Energy = 0.7
Turbulent Dissipation Rate = 0.7
Turbulent Viscosity = 0.9
Solid = 0.9
travis.moulding is offline   Reply With Quote
Old   June 16, 2010, 09:14
Mark Bell
mbell10 is on a distinguished road
check that your grid scale is ok. if your results are way out this can be a factor.
Mark Bell
http://www.markbell.me.uk
mbell10 is offline   Reply With Quote
Old   June 16, 2010, 09:22
Travis Moulding
How do I check the grid scale?
Old   June 16, 2010, 09:26
Mark Bell
from the menu, Mesh -> Scale
you need to check the extents of your domain that they match up the size. Otherwise you will need to expand or contract using the scaling factors.
Mark Bell
Old   June 16, 2010, 09:41
Travis Moulding
Thank you mbell10, I checked the scale between Gridgen and Fluent and the scale was off. I corrected it and started recalculating the solution and it seems to be heading in the right direction. Thanks again!
