Turbulent viscosity and shear rate
Old   June 22, 2010, 12:44
Default Turbulent viscosity and shear rate
shib is on a distinguished road
Hi!
I'm wondering about the connection between turbulent viscosity and shear rate.
I'm using a non-linear model to define the viscosity of a fiber suspension. When the shear rate is about 200 a turbulent viscosity of 1 Pas should be used. According to the author of the doctoral thesis I've gotten the model from this should correspond to the turbulent viscosity of water.
However when I perform simulations with water the turbulent viscosity in the regions where the shear rate is 200 is about 1/10 of 1 Pas. So I wonder if someone knows the reason for this? Is it because my flow is different than his? I thought water would behave in the same way if the shear rate is the same.
Cheers!
shib is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
UDF Viscosity Depending on Shear Rate mannobot FLUENT 0 April 23, 2010 09:46
Help - UDF for solid shear viscosity nbh2801 FLUENT 0 April 21, 2006 07:49
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
