Udf
Old   July 8, 2010, 10:00
Default Udf
Denis Palienko
fabolous is on a distinguished road
hello,
try my first udf. i need a linear profile along a tube in a heatexchanger for the teperature of the wall. the functione is:
T(z) = T(0) - 20 * z / 618
T(z) = Walltemperature subject to the control variable z
T(0) = Walltemperature at the beginning (here 343.15K)
z = control variable
618 mm = Tube legth
I wrote this function for the problem:
#include "udf.h"
DEFINE_PROFILE(temperature_profile,t,i)
real x[ND_ND];
real z;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
z = x[3];
F_PROFILE(f,t,i) = 343.15 - 20*z/618;
end_f_loop(f,t)
My question is, will it work? I try to test it, but could not find out if it works.
Is the main function DEFINE_PROFILE the right choise for this problem?
thx for your help
fabolous is offline   Reply With Quote
Old   July 8, 2010, 10:15
Jouke de Baar
jack1980 is on a distinguished road
Hi, this is almost correct. However, I think you should follow the definition where:
x = x[0]
y = x[1]
z = x[2] (which is the one you want)
I think x[3] is undefined.
Hope this helps!
jack1980 is offline   Reply With Quote
Old   July 8, 2010, 12:07
Denis Palienko
try to do what you told:
#include "udf.h"
real x[ND_ND];
real z;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
x = x[0];
y = x[1];
z = x[2];
end_f_loop(f,t)
but i get this error:
temperature_profile.c:incompatible types in allocation
temperature_profile.c:12: Error: >>y<< is not declared......
if i declare y like that:
real x[ND_ND];
real y;
real z;
i get the same error:
temperature_profile.c: Error: incompatible types in allocation.
what now?
Old   July 8, 2010, 12:15
Denis Palienko
by the way why fluent tell allways:
warning: File`udf_names.c` has modification time 0,13s in teh future....???
and
Warning: no newline at the end of data file...????
Old   July 8, 2010, 12:16
Jouke de Baar
Sorry for confusing, I meant to say: in you original udf replace the line
z = x[3];
with the line
z = x[2];
I think that should work. So:
real x[ND_ND];
real z;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
z = x[2];
end_f_loop(f,t)
Good luck!
Old   July 8, 2010, 12:57
Denis Palienko
the solution is not really what i expected:
if i let me show the contours(Temperature) of the tube after the itaration, i expect a profile like i wrote it in my function. But i see:
at the begin a temperature gradient from 301K to 343K for a short distance, after it the temperature is constant and at the end the same gradient but mirrored.
I got two flows on both sides of the tube, and both entered the exchanger with the temperature value of 283.K
Old   July 8, 2010, 12:58
Denis Palienko
thx for your help jack1980
Old   July 8, 2010, 14:26
Jouke de Baar
Sorry I don't know how to improve this. Hope you can find a way ...
Good luck
Old   July 8, 2010, 14:44
Denis Palienko
i think i got it...have to change the function:
F_PROFILE(f,t,i) = 343.15 - 20.0*z/0.618
sounds silly, just because of the dot but it works
thx
Old   July 8, 2010, 14:47
Jouke de Baar
Ah yes that is it. Great that you found it!
Old   September 23, 2010, 03:47
Default what is the Difference with UDF Fluent 4 and fluent 6 versions
  #11
stage81 is on a distinguished road
I want to know how to use the mesh in version 6 of fluent, because in the UDF version 4 we call the lattice L = I + NI ((J-1) + NJ (K-1)). . For example in version 4 if I want to inject a source term in the mesh 10 20 mesh and I do:
IF (L.EQ.10) THEN
ATERMES = 150
ELSE
FI (L.EQ.20) THEN
ATERMES = 250
ENDIF
but on version 6 I do not know how to do that??
Thanks for you
stage81 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
