July 13, 2010, 05:28 |
2 inlets, 2 UDF
bilalmerei
plz i need an urgent help.
i have to inject oil into water. the problem that water must have a specific profile of velocity so i have to introduce a UDF. and same for the oil. so i don't know how to define 2 UDF and interpret them in each inlet. plz help |
December 12, 2010, 13:26 |
UDF needed too
Rajat
I too need udf function for a fully developed velocity profile at inlet in vertical channel . As i have never worked on Fluent i dont know how udf
have to write is it exactly the same code as in FORTRAN or C as i know both well but udf i dont know |
December 12, 2010, 13:54 |
Real Name :)
UDF's are User Defined Functions
They are typically written in C, but can be written in Fortran. Fluent has a C interpreter built in, so you don't need one unless aspects of the calculation (specific Fluent calls, speed of calculation, etc) require compilation. To impose a fully developed profile at a wall, you must loop over all faces of the wall and set the velocity magnitude (or, perhaps, a vector component) equal to the velocity you obtain from fully developed flow. In the code below, I assume the following: 1) Fully developed laminar flow 2) 2-D flow in the x-direction 3) An inlet face which extends from 0.5 to -0.5 in the y-direction 4) A maximum centerline velocity of 10 Code:
#include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = 10.-10.*(y*y/(0.5*0.5)); } end_f_loop(f, thread) } Go here: http://combust.hit.edu.cn:8080/fluen.../udf/node2.htm for more information on UDFs. ComputerGuy |
December 13, 2010, 02:04 |
Thanks
Rajat
many thanks to ComputerGuy for you help and code I will try to learn and do whatever is needed furthermore.
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
udf for velocity profile in a geometry having two inlets | shubham208011 | Fluent UDF and Scheme Programming | 0 | April 6, 2009 15:13 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
