Easy question (I hope)
Old   July 28, 2010, 23:17
Default Easy question (I hope)
Oscar
Oskirrii is on a distinguished road
Just need confirmation on "where" FLUENT is taking trajectory measurements when it exports X-Y data. It seems to start from 0 meters, but the particles used are 200 microns, so wouldn't FLUENT be referencing each particle at its center (for spheres)? The documentation seems to gloss over this particular detail. Thanks in advance!
-Osk
Oskirrii is offline   Reply With Quote
Old   July 29, 2010, 15:33
Oscar
/bump someone has to know, right?
Old   August 2, 2010, 07:36
Sarah
spring is on a distinguished road
Hi Oskirrii,
you're right. When you are simulating particles as spheres ,Fluent is only referencing to the center points of this spheres, no matter how large their diameter is. This doesn't mean that the diameter does not count at all, but for example the x,y,z position of a sphere particle is taken by it's center point.
I hope this was the right answer to your question.
regards,
spring
spring is offline   Reply With Quote
Old   August 2, 2010, 23:41
Oscar
Ok Thanks! I'm simulating multiphase particle-air lagrangian trajectories in turbulent flow, and I think I can just raise the release surface for the particles to the half-diameter height for each case to get output lagrangian trajectories. I was getting some interesting numerical effects, but this seems to help quite a bit...thanks for the help.
Old   August 2, 2010, 23:42
Oscar
spring, you wouldn't happen to have a reference for where you gleaned this knowledge would you? If not I'll keep looking this week
Old   August 3, 2010, 05:20
Sarah
sorry Oskirrii,
I'vo got this kowledge by experience, because I am simlulating sphere particles (discrete phase),too. In my simulation I wanted the particles to be trapped at the walls of my mesh by contact. I noticed that the particles - no matter how different their diameters were - only stick to the wall, when their centre points "touched" the walls. When you want to make a particle injection by a "file" you must place the start positions of the particles (their centre points) a little bit INSIDE OF the mesh, so that flunt will be able to notice them. Otherwise, I think it won't work...
regards,
spring
Easy question: how to simulate water flow? Freeman FLUENT 6 March 4, 2009 02:31
easy UDF question Oleg FLUENT 4 March 17, 2008 07:07
Question on Sediment Mass Conservation Scheme Wen Long Main CFD Forum 0 July 6, 2004 15:45
Easy question Confused Main CFD Forum 4 May 22, 2004 02:14
Philosophical CFD question Richard Howe Main CFD Forum 14 June 17, 2001 14:41
