have a problem in modeling the freesurfaces?
Old   August 12, 2010, 09:57
Default have a problem in modeling the freesurfaces?
seyedashraf's Avatar
Omid Seyedashraf
seyedashraf is on a distinguished road
Send a message via AIM to seyedashraf Send a message via Yahoo to seyedashraf
im trying to model a spillway
have already designed the gambit file
but have a problem in fluent
seems the water and air are not separated
here is a screenshot
any ideas?
seyedashraf is offline   Reply With Quote
Old   August 12, 2010, 10:25
Omid Seyedashraf
by the way
in the boundry conditions screen
the velocity inlet that _is for Water flow rate_ the phase is mixture and i dont know how to change it
maybe its the reason !
Old   August 12, 2010, 16:08
john
johnp is on a distinguished road
can you clarify what the image represents. i usually view the free surface with a contour plot of volume fraction.
johnp is offline   Reply With Quote
Old   August 13, 2010, 04:10
Omid Seyedashraf
Thanks for your Reply in here
the first screenshot was Velocity Vectors'
now this one :
display>contours > contours of phases > water
like i mentioned before
the problem is , i cannot define water and air
however in Gambit , i have created two different velocity inlets for air and water
but in fluent ....!??
Old   August 13, 2010, 10:30
john
Try this:
1. create a region (possibly more than one) for the air (Adapt -> Region)
2. initialize your solution
3. Patch the volume fraction for air into the region you created, i.e. set the volume fraction of water to zero (or VF of air to 1.0)
4. run simulation
This assumes you've set everything else up correctly (e.g. included gravity, etc.). Fluent has a VOF tutorial modeling a dambreak that may help get you started. Good luck!
Old   August 14, 2010, 15:58
Omid Seyedashraf
I Appreciate your kind help
that DamBreak tutorial was really useful
A problem with solar still modeling Amir Khodabandeh FLUENT 2 April 3, 2011 21:55
A modeling problem of flow in a tube Jason CFX 0 July 21, 2004 15:29
Problem in modeling solidification S. Balasubramanyam CFX 0 January 20, 2004 09:54
modeling of coupled problem Godfrey FLUENT 4 May 22, 2002 14:52
continue the problem with RSM modeling cwflying FLUENT 3 April 28, 2002 07:48
