mixing plane model: too much backflow and does not converge |
August 19, 2010, 23:11 |
skiran
Hi Guys,
I am currently trying to setup a mixing plane model for an Axial flow Turbine model. Both the Stator and rotor have different number of blades at different stages. For example the stator has 4 blades in the 1st stage and 7 in the rest of the stages. I was told by the ANSYS guys that i could extract a periodic volume even though the number of blades vary and use a mixing plane model to capture the interactions between the rotor and stator . I have extracted the periodic volume and set up the mixing plane model in fluent. But when I run it see a lot of back flow at the rotor-stator interfaces (mixing planes) and the solution oscillates and never converges even after running for several iterations My boundary conditions are as follows velocity Inlet: 8.2m/s Pressure outlet: 0Pa pressure inlet-pressure outlet boundaries at the mixing planes I would really appreciate any feedback on this. Thanks |
December 4, 2014, 00:31 |
RacMat
Were you able to find the solution to this problem? I am facing the same problem (reverse flow at the interface).
Thanks! |
