September 8, 2010, 10:39 |
UDF compile error
Hi
When ever I try to compile the UDF file this message appears: error C2109: subscript requires array or pointer type What it should do is make a water tank vibrate with the action of a discrete acceleration in time. Can anyone tell me where's the error and if there is a simpler way of writing this function? Thanks in advance! Here is the function: #include"udf.h" DEFINE_CG_MOTION(wave, dt, vel, omega, time, dtime) { /* these are the accelerations in each time step with deltat=0,02s*/ real a = 0.0580711302903; real b = 0.0145322051660; real c = -0.0404236449378; real d = 0.264406521306; real e = 0.118997934085; real f = -0.118836401038; real g = -0.0401178859565; real h = -0.106652194087; real i = -0.364683929085; real j = -0.323308392979; real k = -0.0480849265815; real l = -0.0303855198926; real m = 0.7425039562890; real n = 1.83807300038; real o = 1.40528558499; real p = -0.171611555011; real q = -1.24726011302; real r = -0.934601363045; real s = -0.760612964632; real t = -1.35824485418; real u = -1.68408008553; real v = -1.19671180747; real w = 0.188111001925; real x = -0.450769504904; real y = -1.40067612412; real tempo; tempo = time; /* change of velocity with each time step */ /* v(i+1) = v(i) + accel*delta t */ if (tempo <= 0.02) {v[0] = v[0] + a*dtime;} if (tempo <= 0.04) {v[0] = v[0] + b*dtime;} if (tempo <= 0.06) {v[0] = v[0] + c*dtime;} if (tempo <= 0.08) {v[0] = v[0] + d*dtime;} if (tempo <= 0.10) {v[0] = v[0] + e*dtime;} if (tempo <= 0.12) {v[0] = v[0] + f*dtime;} if (tempo <= 0.14) {v[0] = v[0] + g*dtime;} if (tempo <= 0.16) {v[0] = v[0] + h*dtime;} if (tempo <= 0.18) {v[0] = v[0] + i*dtime;} if (tempo <= 0.20) {v[0] = v[0] + j*dtime;} if (tempo <= 0.22) {v[0] = v[0] + k*dtime;} if (tempo <= 0.24) {v[0] = v[0] + l*dtime;} if (tempo <= 0.26) {v[0] = v[0] + m*dtime;} if (tempo <= 0.28) {v[0] = v[0] + n*dtime;} if (tempo <= 0.30) {v[0] = v[0] + o*dtime;} if (tempo <= 0.32) {v[0] = v[0] + p*dtime;} if (tempo <= 0.34) {v[0] = v[0] + q*dtime;} if (tempo <= 0.36) {v[0] = v[0] + r*dtime;} if (tempo <= 0.38) {v[0] = v[0] + s*dtime;} if (tempo <= 0.40) {v[0] = v[0] + t*dtime;} if (tempo <= 0.42) {v[0] = v[0] + u*dtime;} if (tempo <= 0.44) {v[0] = v[0] + v*dtime;} if (tempo <= 0.46) {v[0] = v[0] + w*dtime;} if (tempo <= 0.48) {v[0] = v[0] + x*dtime;} if (tempo <= 0.50) {v[0] = v[0] + y*dtime;} } |
September 8, 2010, 17:09 |
Micael
Rep Power: 18 |
If I understand what you try to do, you wrote v[0], but it should be vel[0].
Also, it looks to me that your "if" structure does not do what you expect it to do. As an example, if the statement (tempo <= 0.02) is true, then every statement of other "if" is also true. Hence, they will be all executed sequentially. In such case you get: v[0] = v[0] + a*dtime + b*dtime + c*dtime + ... + y*dtime |
September 9, 2010, 06:42 |
Re
Thanks a lot!
It works fine now Regards feupes |
September 13, 2010, 10:52 |
Re
The function works fine now but it only executes once every 0,02 seconds!
Does anyone know how to make it execute every fluent time step? Thanks feupes |
September 13, 2010, 20:04 |
Micael
Rep Power: 18 |
How does look like the function now?
September 14, 2010, 05:26 |
Re
This is the one I used:
#include"udf.h" DEFINE_CG_MOTION(wave, dt, vel, omega, time, dtime) { real a = 0.0580711302903; real b = 0.0145322051660; real c = -0.0404236449378; real d = 0.264406521306; real e = 0.118997934085; real f = -0.118836401038; real g = -0.0401178859565; real h = -0.106652194087; real i = -0.364683929085; real j = -0.323308392979; real k = -0.0480849265815; real l = -0.0303855198926; real m = 0.7425039562890; real n = 1.83807300038; real o = 1.40528558499; real p = -0.171611555011; real q = -1.24726011302; real r = -0.934601363045; real s = -0.760612964632; real t = -1.35824485418; real u = -1.68408008553; real v = -1.19671180747; real w = 0.188111001925; real x = -0.450769504904; real y = -1.40067612412; real tempo; tempo = time; if (tempo <= 0.02) {vel[0] = vel[0] + a*dtime;} if (0,02 < tempo <= 0.04) {vel[0] = vel[0] + b*dtime;} if (0,04 < tempo <= 0.06) {vel[0] = vel[0] + c*dtime;} if (0,06 < tempo <= 0.08) {vel[0] = vel[0] + d*dtime;} if (0,08 < tempo <= 0.10) {vel[0] = vel[0] + e*dtime;} if (0,10 < tempo <= 0.12) {vel[0] = vel[0] + f*dtime;} if (0,12 < tempo <= 0.14) {vel[0] = vel[0] + g*dtime;} if (0,14 < tempo <= 0.16) {vel[0] = vel[0] + h*dtime;} if (0,16 < tempo <= 0.18) {vel[0] = vel[0] + i*dtime;} if (0,18 < tempo <= 0.20) {vel[0] = vel[0] + j*dtime;} if (0,20 < tempo <= 0.22) {vel[0] = vel[0] + k*dtime;} if (0,22 < tempo <= 0.24) {vel[0] = vel[0] + l*dtime;} if (0,24 < tempo <= 0.26) {vel[0] = vel[0] + m*dtime;} if (0,26 < tempo <= 0.28) {vel[0] = vel[0] + n*dtime;} if (0,28 < tempo <= 0.30) {vel[0] = vel[0] + o*dtime;} if (0,30 < tempo <= 0.32) {vel[0] = vel[0] + p*dtime;} if (0,32 < tempo <= 0.34) {vel[0] = vel[0] + q*dtime;} if (0,34 < tempo <= 0.36) {vel[0] = vel[0] + r*dtime;} if (0,36 < tempo <= 0.38) {vel[0] = vel[0] + s*dtime;} if (0,38 < tempo <= 0.40) {vel[0] = vel[0] + t*dtime;} if (0,40 < tempo <= 0.42) {vel[0] = vel[0] + u*dtime;} if (0,42 < tempo <= 0.44) {vel[0] = vel[0] + v*dtime;} if (0,44 < tempo <= 0.46) {vel[0] = vel[0] + w*dtime;} if (0,46 < tempo <= 0.48) {vel[0] = vel[0] + x*dtime;} if (0,48 < tempo <= 0.50) {vel[0] = vel[0] + y*dtime;} } I also came up with this one for the first 12 accelerations but it doesn't work at all.. #include "udf.h" DEFINE_CG_MOTION(wave, dt, vel, omega, time, dtime) { int i; real a [12] = { 0.145322051660, -0.404236449378, 2.64406521306, 1.18997934085, -1.18836401038, -0.401178859565, -1.06652194087, -3.64683929085, -3.23308392979, -0.480849265815, -0.303855198926, 7.425039562890 }; for (i = 1 ; i <= 12 ; i++) {vel[0]= vel[0] + dtime*a[i-1]; if (time <= 0,02*i) {i=i-1;} } } Thanks for your help! |
September 14, 2010, 10:36 |
Micael
Rep Power: 18 |
First of all, there is some confusion in your code with decimal point and decimal comma. Only use decimal point.
Well, if I understand what you try to do, I would do this: #include "udf.h" DEFINE_CG_MOTION(wave, dt, vel, omega, time, dtime) { real a[25] = {0.0580711302903, 0.0145322051660, -0.0404236449378, 0.264406521306, 0.118997934085, -0.118836401038, -0.0401178859565, -0.106652194087, -0.364683929085, -0.323308392979, -0.0480849265815, -0.0303855198926, 0.7425039562890, 1.83807300038, 1.40528558499, -0.171611555011, -1.24726011302, -0.934601363045, -0.760612964632, -1.35824485418, -1.68408008553, -1.19671180747, 0.188111001925, -0.450769504904, -1.40067612412}; int i; i = floor(time/0.02); vel[0] += a[i]*dtime; } |
September 15, 2010, 01:17 |
udf problem
krishna
i have a program to generate stock's second order waves. but after loading in fluent the file name is not showing in the DYNAMIC ZONE WINDOW...and an error is showing that no moving zone selected!!...
what is Error: Divergence detected in AMG solver: x-momentum? can u please help me.. i am including the udf. thank u in adv #include "udf.h" #define PI 3.14159265 #define GRAV 9.81 #define H 1.5 #define D 10.0 #define T 6 #define L 20 DEFINE_PROFILE(x_velocity, thread, position) { real x[ND_ND]; real y; real AA,BB,CC,DD,EE,FF,GG,LL,ZZ,K; face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); F_CENTROID(x,f,thread); y = x[1]; ZZ= y - D; K = 2*PI/L; AA= cosh (K*(ZZ + D)); BB= cosh (K* D); CC = sinh (K*D); DD= cos (PI/2.0 -2.0 *PI*(t/T)); EE= cos (2.0*(PI/2.0 -2.0 *PI*(t/T))); FF= cosh (2.0*K*D); GG= cosh (2.0*(K*(ZZ + D))); LL= D+(H*DD/2.0)+(PI*H*H/(8.0*L))*(BB/pow (CC,3.0))*(2.0+FF)*EE; if (y <= D) F_PROFILE(f,thread,position)=H/2.0*(GRAV*T/L)*AA*DD/BB+0.75*PI*PI*H*H/(L*T)*GG*EE/pow(CC,4.0); else if (y <= LL) F_PROFILE(f,thread,position)=H/2.0*(GRAV*T/L)*BB*DD/BB+0.75*PI*PI*H*H/(L*T)*FF*EE/pow(CC,4.0); else F_PROFILE(f, thread, position) = 0; } end_f_loop(f, thread) } DEFINE_PROFILE(y_velocity, thread, position) { real x[ND_ND]; real y; real K,MM,NN,OO,PP,QQ,RR,SS,TT,UU,VV,WW,ZZZ; face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); F_CENTROID(x,f,thread); y = x[1]; ZZZ= y - D; K = 2*PI/L; MM= sinh (K*(ZZZ + D)); NN= cosh (K* D); OO= cos (PI/2.0 - (2.0 *PI* t/T)); WW= cos (2.0*(PI/2.0 -2.0 *PI*(t/T))); VV= sin (PI/2.0 - (2.0 *PI* t/T)); QQ= sin (2.0*(PI/2.0 -2.0 *PI*(t/T))); RR= sinh (K*D); SS= cosh (2.0*K*D); TT= sinh (2.0*(K*(ZZZ + D))); UU= sinh (2.0*K*D); PP= D+(H*OO/2.0)+(PI*H*H/(8.0*L))*(NN/pow (RR,3.0))*(2.0+SS)*WW; if (y <= D) F_PROFILE(f,thread,position)=H/2.0*(GRAV*T/L)*MM*VV/NN+0.75*PI*PI*H*H/(L*T)*TT*QQ/pow(RR,4.0); else if (y <= PP) F_PROFILE(f,thread,position)=H/2.0*(GRAV*T/L)*RR*VV/NN+0.75*PI*PI*H*H/(L*T)*UU*QQ/pow(RR,4.0); else F_PROFILE(f, thread, position) = 0; } end_f_loop(f, thread) } |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
