Time-Varying Inlet Velocity
Old   January 27, 2010, 11:25
Default Time-Varying Inlet Velocity
CFDFSI
cfdfsi is on a distinguished road
I'm trying to impose time-varying velocity at the inlet. Can someone guide me on how to impose the bc ?
Thanks.
cfdfsi is offline   Reply With Quote
Old   January 27, 2010, 16:00
DoHander is on a distinguished road
Use a UDF - you will find an example of a an unsteady velocity boundary condition in the Fluent UDF manual.
Do
DoHander is offline   Reply With Quote
Old   January 27, 2010, 16:18
CFDFSI
thanks for the reply.
for example: if i want v(t) = 0.1*t for 0< t < 1 at the inlet,
is the following UDF correct ?
#include "udf.h"
DEFINE_PROFILE(transient_velocity, thread, position)
  float t, velocity;
  face_t f;
  t = RP_Get_Real("flow-time");
  velocity = 0.1*t;
  begin_f_loop(f, thread)
   F_PROFILE(f, thread, position) = velocity;
  end_f_loop(f, thread)
Old   January 27, 2010, 19:25
Looks OK (I didn't tested your code in Fluent), however if you want to apply this only for 0< t < 1 ... you've missed a test condition.
Do
Old   September 24, 2010, 16:26
mrestrepo30 is on a distinguished road
dear cfdfsi,
I was using your UDF to impose a time varying velocity inlet on a 3D cylinder. However, I'm not getting a plug profile with it.
Did anything similar happened to you?
Thanks!
mrestrepo30 is offline   Reply With Quote
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
How to set a time varying velocity field as a BC? Mikro OpenFOAM Pre-Processing 5 March 19, 2009 04:38
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 04:56
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
