Regarding DES
Old   October 13, 2010, 02:37
Default Regarding DES
Parag
paragnsk is on a distinguished road
Hello everybody,
I am trying to simulate (3D simulation) the flow past blunt base aerofoil at zero AOA and at low speed using DES. In DES approach, local grid size with maximum of delta x, delta y and delta z is taken into consideration. My question is, refinement of grid in two direction keeping same spacing in third direction (previous maximum among delta x, y and z) will affect the solution? (since DES will consider again the same maximum of delta x, y and z)
Regards,
Parag
paragnsk is offline   Reply With Quote
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 05:59
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body Phil Main CFD Forum 0 January 8, 2008 09:04
Problem with DES analysis mehul CFX 7 April 25, 2006 07:57
Problem with DES model mehul Phoenics 0 April 12, 2006 08:00
Problem with DES model mehul FLUENT 0 April 12, 2006 07:59
