reaction panel or udf
Old   October 13, 2010, 13:42
Default reaction panel or udf
raymond
wlt_1985 is on a distinguished road
I am going to model a chemical reaction instead of combustion, i.e esterification. Is it a necessary for me to compute the chemical reaction with udf? Or may I just using the reaction panel available in Fluent? Please help.
wlt_1985 is offline   Reply With Quote
Old   October 13, 2010, 23:57
chétan
coalgas is on a distinguished road
you can use reaction panel, for reaction between acid and alcohol. UDF will be useful if you want to use customerised reaction rate equation oresle Fluent will calculate reaction rate with inbuilt models.
coalgas is offline   Reply With Quote
Old   October 14, 2010, 00:57
Smile
raymond
Thanks for help.
Old   October 15, 2010, 03:59
raymond
I have found that the chemical species used in esterification are not available in database. So, I define the individual properties of chemical species. Is it a necessary for me to define the properties of that mixture of chemical species? Can it be just ignored?
Old   October 15, 2010, 12:22
raymond
I need to define my own chemical species for reaction. Hence I need to define the properties of mixture. The properties of mixture are just for properties of mixture of reactants? Or properties of mixture of reactantsand products? Please help.
Old   October 18, 2010, 02:50
chétan
you need to define only properties of reactants. Properties of Mixture usually determined by various models by selecting appropriate options from Mixture panel. Mixture panel is the place where you should define your reaction and select species.
Old   October 18, 2010, 07:47
raymond
Thanks for help
UDF about reaction in fluent5.4 Mark FLUENT 5 May 1, 2014 17:39
UDF for catalyst volumetric reaction, temperature overshoot though rate is small elmcmaster FLUENT 0 October 11, 2010 09:37
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 13:20
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 14:04
