January 10, 2011, 10:42 |
Maxime Perelli
Rep Power: 41 |
First do the tutorial and you will understand some basics.
Then you can work with your project.
In memory of my friend Hervé: CFD engineer & freerider |
January 11, 2011, 11:45 |
no183
Rep Power: 15 |
i done the tutorial bro. But unfortunately, i need the gambit meshing tutorial? because i still not quite clear with the function, map, cooper etc.
January 16, 2011, 00:26 |
no183
Rep Power: 15 |
sorry was busy this few day. I got it. Now i know, the purpose i create the block(brick) is used to mesh inside it so that i can mesh the air(space)? just my 2 cents
January 20, 2011, 07:57 |
no183
Rep Power: 15 |
where are u max, having trouble in meshing still
January 20, 2011, 07:59 |
Maxime Perelli
Rep Power: 41 |
what kind of meshing trouble?
January 20, 2011, 08:40 |
no183
Rep Power: 15 |
i cant mesh the vvolume in HEX, only tet
January 20, 2011, 08:51 |
Maxime Perelli
Rep Power: 41 |
You have a complex geometry, forget trying to mesh it with hexa on the fly. You will need many volume decomposition and patience for achieving it.
Even with tetra, you will need to decompose your volume (but less than with hexa) and it won't be easy at all to get a good tetra mesh (skewness < 0.9) I would try to mesh it first with tetra, and use Hexcore scheme: it will fill your domain with hexa.
January 20, 2011, 08:53 |
no183
Rep Power: 15 |
Ya my skewness >0.97.. can i send u my dbs for verification?
January 20, 2011, 09:08 |
#9 |
Maxime Perelli
Rep Power: 41 |
spoload your dbs on a sharre server I will check it tomorrow.
In examine Mesh, set the lower skewness to 0.9 (instead of 0) and Update:you will see where are all the cells with skewness above 0.9. Then check if you don t have small edges, small angles, or any topology issue in those areas
January 20, 2011, 09:16 |
#10 |
no183
Rep Power: 15 |
i have save in in dbs and zip it.. will upload it later tonight.
January 20, 2011, 11:17 |
#11 |
no183
Rep Power: 15 |
http://rapidshare.com/files/44359048...shing_done.zip
i have upload it, kindly help me check, thanks ! |
January 21, 2011, 01:14 |
#12 |
Maxime Perelli
Rep Power: 41 |
your geometry isn't ready for meshing:
*delete volume.5 *copy face.3048 with (0 0 -160.5) --> new face.3049 *split volume.2 with face.3049 --> new volume.7 *delete volume.7 *copy face.3043 with (0 0 149) --> new face.3052 *split volume.2 with face.3052 --> new volume.7 *delete volume.7 *copy face.3056 with (-35 0 0) --> new face.3057 *split volume.2 with face.3057 --> new volume.7 *delete volume.7 *copy face.3055 with (0 35 0) --> new face.3084 *split volume.2 with face.3084 --> new volume.7 *delete volume.7 *copy face.3087 with (35 0 0) --> new face.3089 *split volume.2 with face.3089 --> new volume.7 and volume.8 *delete volume.8, volume.3, volume.4, volume.6 Now your geometry is ready for meshing, but it will fail because of topology, especially in fans area (just read where gambit failed to mesh surfaces, and fix) NB: the generated id's from entity could differ from OS, so check id's in the transcript window
January 21, 2011, 08:27 |
#13 |
no183
Rep Power: 15 |
Bro, i have done what u ask, unfortunately, i dont know what is going wrong, some how, i still got error
January 21, 2011, 08:38 |
#14 |
Maxime Perelli
Rep Power: 41 |
there are not errors: hollow parts are your solid parts, which are not in interest since you don't want solid conduction.
You have substracted them. Now you have fluid domain. Same theme here:http://www.cfd-online.com/Forums/ans...g-help-me.html
January 21, 2011, 08:42 |
#15 |
no183
Rep Power: 15 |
hmm? how should i subtract now?
January 21, 2011, 08:48 |
#16 |
Maxime Perelli
Rep Power: 41 |
why do you want to mesh those parts?
do you want to compute solid conduction in solid elements?
January 21, 2011, 08:52 |
#17 |
no183
Rep Power: 15 |
nope, my scope is convection only. So i will do the convection part first.
January 21, 2011, 08:56 |
#18 |
Maxime Perelli
Rep Power: 41 |
Then go and mesh the model you displayed
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
Boundary layer meshing problem in Gambit | Crystal | FLUENT | 0 | June 12, 2009 20:58 |
GAMBIT problem with 3D Boundary Layer when meshing | Anthony Haroutunian | FLUENT | 2 | March 26, 2008 02:02 |
Help Urgent about changing boundary condition | Anjum Naveed | FLUENT | 7 | August 14, 2006 12:25 |
Boundary Layer Meshing of a nosecone | Chris | FLUENT | 1 | March 15, 2005 12:42 |
