Global c.sys in GAMBIT or FLUENT
Old   October 16, 2006, 03:39
Default Global c.sys in GAMBIT or FLUENT
Kasper Skriver
Hi everyone,
Returning to my question from some days ago (where nobody seems to know the answer). The solution is to import the same partial geometry in FLUENT and change the global coordinate system in either GAMBIT or FLUENT between each import.
Does anyone know how to translate the global coordinate system in GAMMBIT. It is easy enough in FLUENT, where theres only one c.sys. and an option named "translate". But what about GAMBIT.
Old   October 16, 2006, 04:25
Default Re: Global c.sys in GAMBIT or FLUENT
zxaar
your question is fuzzy at the best. if you can translate nodes in fluent, you can translate volumes in gambit. in gambit nodes are attached to volumes (in fluent when you translate the nodes you are actually translating the fuild asscoiated with it, same effect as gambits volume translate).
Old   October 16, 2006, 04:40
Kasper Skriver
What is fuzzy about this:
"Does anyone know how to translate the global coordinate system in GAMBIT"
In FLUENT you can translate (move) the global and only coordinate system by the option -Grid-Translate... where you set the new origo by the translate offsets.
In GAMBIT you have or can have several local coordinate systems, and logically only one global (c.sys.1). When you export the mesh to FLUENT the global coordinate system from GAMBIT is used in FLUENT.
My tech support from FLUENT says: change the coordinate settings in GAMBIT or in FLUENT. Im loosing some freedom if i do it in FLUENT. So to summarize
Does anyone know how to translate(move) the global coordinate system c.sys.1 in GAMBIT??
Old   October 16, 2006, 05:07
zxaar
well now i understood. I was thinking you want to move mesh or nodes etc, but you have made it very clear that you want to move the global cordinate system. Now there is nothing fuzzy about it. Best of luck with it.
Old   November 10, 2010, 12:49
C.K.
Constantine is on a distinguished road
hello there,
Its a bit late, but have u managed to find the solution to ur question???? i face the same problem!!
Constantine K.
Constantine is offline   Reply With Quote
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 12:10
[GAMBIT] SketchUp Pro to Fluent or Gambit CFD Steve Johnson ANSYS Meshing & Geometry 3 May 16, 2013 02:05
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) hadikhayyamian ANSYS Meshing & Geometry 5 December 21, 2010 12:28
gambit with linux and fluent 12.1 kharnabnew FLUENT 0 October 5, 2010 09:33
Fluent case file into Gambit Eric R. FLUENT 7 July 17, 2002 14:11
