3D dynamic mesh negative volume,help me
Old   November 17, 2010, 03:45
Smile 3D dynamic mesh negative volume,help me
gao long
jdqcgl is on a distinguished road
Send a message via MSN to jdqcgl
hi,all.I am trying to move a face in a 3d model and i keep getting negative volume when i run the mesh motion after several steps.I used smoothing and remeshing,and the parameters are gived by refering to mesh scale info.I have reduced the time step and still it didn't work.I also changed the remeshing parameters but no go.I find the grids which are near the moving wall didn't remeshing,the grids deform until negetive volume is found.what should I do?I have troubled with this problem sevral days,i need help.The cross-section profile of the 3d model after deformation is given.
jdqcgl is offline   Reply With Quote
Old   November 17, 2010, 04:49
JohannVV is on a distinguished road
hi, may be i can help you. but first could you show me your model ant the dynamic mesh settings for all faces.
JohannVV is offline   Reply With Quote
Old   November 17, 2010, 05:32
Smile
gao long
Hi,JohannVV,thank you for your reply.Could you give me your e-mail,I will send a message to you.Because I don't known how to put the model on the internet.My email is gy8412845@163.com .QUOTE=JohannVV;283732]hi, may be i can help you. but first could you show me your model ant the dynamic mesh settings for all faces.[/QUOTE]
Old   November 17, 2010, 09:55
hi I do not want put my e-mail adress to the internet. you can make some pistures and attach them to a post.
Old   November 18, 2010, 00:51
gao long
hi,I have inserted a picture on the internet,but I don't know why I can't see it.Maybe you can send a email to me ,then I will send the model which include document of mesh and cas.Trust me,I will not give your email to others and I willnot disturb you.Thank you very much,my email is gy8412845@163.com ,send a email to me.This is address of a cross-section picture of my model after deform .http://photo.163.com/gy8412845/big/#...&id=6568347351
3d dynamic mesh
Regarding Negative volume detected in Dynamic mesh Vinay Morabad FLUENT 10 December 16, 2015 00:31
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Incylinder Dynamic Mesh Creating Negative Volume Sujtih FLUENT 3 August 1, 2006 15:53
Dynamic Mesh, negative volume! ROOZBEH FLUENT 2 June 22, 2006 20:51
