convective cooling in channel flow
Old   November 17, 2010, 13:25
Default convective cooling in channel flow
Stef
Stef06 is on a distinguished road
I am trying to model convection as air flows over a surface in FLUENT. To do this, I have made the surface a WALL boundary in gambit, and specified a negative heat flux in FLUENT (since the surface will be cooling the air). Then, also in FLUENT, I specified the inlet temperature as 300K and its velocity, ran the calculation, and displayed the temperature contour.
The solution, however, is not making sense. The entire channel temperature is now 330K, with colder temperatures very close to the cooling surface.
Would this be the right way to model convection? Or what else could be messing up my solutions?
Any help is greatly appreciated!!
Stef06 is offline   Reply With Quote
convection, fluent, gambit, heat flux, wall boundary conditions
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
Flow within a thin channel al0Vera FLUENT 0 June 15, 2009 10:20
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
supersonic channel flow Ingo Meisel Main CFD Forum 15 August 26, 2005 07:00
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
