November 20, 2010, 08:41 |
How to display Coefficient of lift (Cl)
umar
I am running Fluent and trying to calculate the lift coefficient for a symmetrical aerofoil. I want to compare the value of CL to the thin aerofoil theory, but i cannot seem to find out how to display the CL for AOA 2 degrees in fluent. Any help is much appreciated. Thank you |
November 25, 2010, 08:09 |
Burak
Rep Power: 17 |
go to report-forces
select your airfoil (which must be a wall) select lift direction (ex: set y = 1) here you have the results. but dont forget to set reference values (velocity, area, etc.) |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 11:48 |
Lift force or coefficient of lift | Rola | FLUENT | 1 | November 12, 2006 13:29 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 10:21 |
Help needed - lift coefficient on front/rear axle | Jan Jagrik | FLUENT | 0 | September 21, 2000 10:21 |
