November 23, 2010, 02:48 |
steady to unsteady
raymond
Rep Power: 16 |
how to implement the results obtained from steady state modeling to unsteady state modeling? is it just switch the steady state condition to unsteady state condition in solver after the steady state condition has been converged?
Thanks |
November 23, 2010, 03:46 |
Kristian Etienne Einarsrud
Rep Power: 15 |
Yes, the solution method you sketch should work without any problems; switch to the unsteady solver and continue your calculations from where the steady one stopped.
Cheers! |
November 23, 2010, 05:34 |
raymond
Rep Power: 16 |
November 24, 2010, 02:10 |
raymond
Rep Power: 16 |
November 24, 2010, 03:06 |
Rep Power: 15 |
No, why would you want to do that?
That will reset your solution to what it was before you started the steady simulation.. |
November 24, 2010, 03:43 |
raymond
Rep Power: 16 |
December 4, 2010, 16:17 |
Rep Power: 16 |
Hey everyone,
I wanted to ask a couple of stuff related to unsteady modelling: I'm doing the exact same thing you discussed; I first get a converged steady-state solution, then I run it unsteady. Here's what happens though: - I'm analyzing the wake of a 3D cylinder in cross flow. Since for most Re numbers (including mine) the wake is unsteady, so the contour plots of variables oscillate inside the wake. The funny thing is, for the first 90 - 100 time steps, the wake oscillates, but after that point, and even when the residuals go down and flatten out at low levels, the wake oscillation disappears. The wake looks symmetric, like the average, mean version of all the oscillations. Any idea why this is happening? Could it be related to the size of the time step and/or the number of pseudo-time iterations at each time step? Or could it be related to the boundary conditions? Cheers, Ozgur |
steady and unsteady conditions | uday | Main CFD Forum | 0 | November 17, 2009 05:17 |
Steady needs unsteady. | nico | Main CFD Forum | 0 | September 21, 2007 04:50 |
Turbulent: Steady or Unsteady: confusion | prem | FLUENT | 0 | March 30, 2006 10:40 |
Difference results between Steady and Unsteady? | Giang T Vu | FLUENT | 6 | May 22, 2004 06:37 |
steady or unsteady? (in dpm) | winnie | FLUENT | 1 | April 28, 2003 11:30 |
