boundary conditions
Old   December 5, 2010, 21:26
Default boundary conditions
primateiro is on a distinguished road
hello!
I'd like to know, how to build internal boundaries (fan, radiator, porous jump, wall, and interior) in a 3D model.
thanks
primateiro is offline   Reply With Quote
Old   December 6, 2010, 05:02
lw
perdita is on a distinguished road
you should do this when building your mesh. there should be the option to define boundary zones somewhere.
otherwise in fluent, you should go to define ->boundary conditions, and then click on the physical features and assign them the relevant boundary conditions.
perdita is offline   Reply With Quote
Old   December 6, 2010, 06:58
jpo
jpo is on a distinguished road
if in gambit you cut 2 volumes with a face but keep the 2 volumes "connected", you will have a single face on the border between the 2 volumes.
It can be defined as "interior". This means no boundary conditions are applied to it, it is NOT treated as a boundary, but as part of the volume
jpo is offline   Reply With Quote
Old   December 6, 2010, 08:08
Shen
sinoalps is on a distinguished road
if in gambit ,you can set it in the right panel ,the third icon at the top
sinoalps is offline   Reply With Quote
Old   December 26, 2010, 18:40
hi perdita
look, i've tried to build internal boundaries from my model mesh but i can't find the right command tool (in gambit) to make this work out.
please i need a help about this, if someone has any idea...
thanks
Old   December 27, 2010, 04:38
Vishnu Prasad
vishnukmd7 is on a distinguished road
I don't know if this is what you are looking for but in the workbench meshing app , you can create named selections while meshing and apply these boundary conditions once the model has been imported to fluent
vishnukmd7 is offline   Reply With Quote
Old   January 10, 2011, 10:40
hi vishnukmd7
Look, i've tried to follow your indications but i can't solve the problem. Please i'd like to you give me some more info.
Now i'll give some more info about the problem that i have to solve:
- I've built a box, inside this box i have to consider one or more faces this faces will become differents ventilators (like inlet vent, fan, radiator...). The real problem is to make that face(s) become part of the box (the only volume mesh considered for fluent).
Thanks a lot for all the sugestions
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
