intiror faces
Old   December 6, 2010, 11:13
Angry intiror faces
lyly
ezabille is on a distinguished road
hi
i have a problem
, when i export 3d volumes to fluent some of interior faces fluent define them as walls not interior
and they must be a coupled wall or interior to study heat transfear throw them
i try to define these faces from gambit as interior but i found a problem when i export to fluent
so how can i change walls in to interior or coupled walls?
can any one tell me?
ezabille is offline   Reply With Quote
Old   December 7, 2010, 01:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
First I have no experience with solid conduction in Fluent.
But if you use interior or internal BC, Fluent understands your flow will pass trough this section. If the surface on which you applied this interior BC is closing a volume, I assume gambit will export it as wall (else your volume isn't closed)
In you case you need to define your surface as wall and then in Fluent you set your coupled wall in the Thermal section from Wall.
Check online Help Chapter 7.13.1 "Input at Wall Boundaries"
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 7, 2010, 22:57
jpo
jpo is on a distinguished road
Make sure in gambit your interior face doesn't have a duplicate somehow. It shouldn't be a problem for fluent to recognize it as an interior
To get a good interior face : in gambit, split a volume with a face, keep the split volumes connected. Erase the splitting face. Mark the dividing face as 'interior'
Fluent will recognize it as such
jpo is offline   Reply With Quote
