fluent define limiting time
Old   January 3, 2011, 01:13
Default fluent define limiting time
ekkapong
nuengao is on a distinguished road
Dear all
please give me your suggestion about how to set fluent simulation for limiting time. for example
I have model as shown upper figure.
fluid inlet: 1.8 m/s, 588 k
fin that is surrounded by fluid: 273 k teperature
outlet: outflow
the fluid will transfer the heat to the fin.
I'd like to use CFD postprocessing(temperature contour) after 20 second.
please help me
nuengao is offline   Reply With Quote
Old   January 3, 2011, 02:10
ekkapong
Can I set time to Transient on General settings and set the Run calculation as following:
Time step size(s)=1
number of time steps= 20
max Iterations/TIme step= 10
Could anyone give me your suggestion that it is correct or not? please
Old   January 3, 2011, 21:07
Real Name :)
ComputerGuy is on a distinguished road
Nuengao,
Your approach is correct. The final time of the simulation will be:
N*\Delta t
Where N is the number of time steps and \Delta t is the time step size.
Typically, having a transient simulation converge (per time step) in 5-7 iterations is reasonably good, thus having a setting of a maximum of 10 iterations per time step is OK. However, in your case I would be concerned about the size of the time step -- ensure that the simulation is actually converging after 10 iterations, not simply marching to the next time step because of the maximum iteration count you've imposed.
Regards,
ComputerGuy
ComputerGuy is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
Fluent case to OpenFOAM conversion umichsct OpenFOAM 4 April 23, 2011 14:59
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
