Large source term in species equation
Old   January 3, 2011, 17:59
Default Large source term in species equation
MACFD is on a distinguished road
Hi ,
I am trying to add a large source term in species equation. I have two species one has a mass fraction of 3e-5 (particle phase). Diffusivity of particles is really samll (D=1e-8 m^2/s).
Fluent does not converge when my source term is really large compared to diffusion term. I tried to gradually add the source term as 1/50 of the term, then 1/40,... It converges up to 1/4 of the source term and does not work afterward.
Could anybody help me resolve this issue. My guess is that divergence happens due to upwinding. my source term is not defined for upwinding. Any though is appreciated.
Thanks,
MA
MACFD is offline   Reply With Quote
Old   January 3, 2011, 21:39
Real Name :)
ComputerGuy is on a distinguished road
MA,
Have you tried lowering the under-relaxation factors for the species mass fractions, or perhaps lowered your time step size? Decrease the time step by an order of magnitude and see if you can't get it to work.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   January 4, 2011, 01:23
COMPUTERGUY,
Thanks for your prompt reply. My case is steady state.
I lowered the under-relaxation factor and it converged. I should check the results though to see if they are rational.
Your suggestion was great. Thanks a lot.
MA
Old   January 4, 2011, 07:58
Real Name :)
Definitely check the results. Any time you lower the URF, the residuals will drop. Thus, you can occasionally "force" the residuals lower than your convergence criteria. To be on the safe side, you can set the residual criteria to some very low value, then monitor the residuals to see that they plateau (or, monitor a value of interest and wait until it stabilizes).
ComputerGuy
Old   January 4, 2011, 14:16
I lowered URF value for the species. As you mentioned, it lowered the residuals and I defined a really small value for convergence criterion.
Unfortunately, the results are not rational. Center line values look fine but near wall I get really high concentration values (particles) that do not seem correct.
I wonder if you have any other suggestions. Thanks a lot,
MA
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
Reaction Source Term in Steady Species transport equation cfdvenkatesh Main CFD Forum 0 August 19, 2010 09:28
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
species source term reaction Andrew FLUENT 3 May 27, 2005 12:35
