January 9, 2011, 05:21 |
Dynamic Mesh - negative cell volume
Hello All and thanks for reading,
I am trying to build a model for a peristaltic pump in 2 dimensions. I used the "DEFINE_GRID_NOTION" to program a motion of progressive wave, to the walls. When I am trying to run the calculation FLUENT tells me it couldn't proceed because of "negative cell volume detected". If anyone know what sould I do, I will be glad Thnks Ori |
January 22, 2011, 06:05 |
Denis Tschumperle
Lower your time step. If you are doing layering, time step must be adapted so that only one layer of cell will be destroyed in one time step. Doing otherwise will result in negative volume cells.
dynamic mesh, grid motion, moving wall |
Regarding Negative volume detected in Dynamic mesh | Vinay Morabad | FLUENT | 10 | December 16, 2015 00:31 |
negative cell volume during dynamic meshing | Tamjid | FLUENT | 1 | September 5, 2011 02:33 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Negative volume in dynamic mesh | Max | FLUENT | 1 | August 7, 2006 05:18 |
