cannot input CATIA *.model into gambit
Old   January 10, 2011, 07:52
Exclamation cannot input CATIA *.model into gambit
soilinkin is on a distinguished road
I have output a *.model file from CATIA, where gambit have such option to input the CATIA V4 *.model file. however when I input the file into gambit it shows "input file has units 'mm'." and the file cannot be input. Then I change the length unit into "m" in CATIA, the problem still remains. I need help to solve this thing.
soilinkin is offline   Reply With Quote
Old   January 11, 2011, 00:55
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you click on the "fit to window" icon? (botto-right, up to the axis)
If you don't get any error in the transcript window, it should be successfull.
Don't you have any line about "Imported" right after "Input file has units "mm"?
PS: Gambit doesn't provide any unit, you will have to scale your geometry in the sover
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 11, 2011, 03:57
J.-H. Wang
f0208secretx is on a distinguished road
For your reference, I always have minor problems with .model file and it is really annoying. You could perhaps try .stp (referred in Gambit as STEP), it is better in my opinion.
f0208secretx is offline   Reply With Quote
Old   January 11, 2011, 06:47
I have no problem in inputing .stp file, but the .model is still impossible to input.
after the "input file has units'mm'." it says "ERROR: translation failed", so it is not input into the gambit, I still don't know why.
Old   January 11, 2011, 06:59
-mAx-'s Avatar
Maxime Perelli
Then import Step File, unless you already imported other geometry from catia and you want absolutely work with this kind of import.
can you provide the file, we could test the import
Old   January 11, 2011, 07:11
i'm just trying to mesh in CATIA and then input into gambit, it's a test with a simple model. if this fails then it is a dead end, i have to mesh in gambit or other software.
But i still want to know if anything is wrong with me or what, can anyone please create a simple .model file and try inputing into gambit to see if it works? thanks.
Old   January 11, 2011, 07:20
-mAx-'s Avatar
Maxime Perelli
do you have fluent for catia, with mesher, pre- post-processing and solver integretated?
Old   January 11, 2011, 07:34
yes, the pre-processing is gambit.
Old   January 11, 2011, 07:44
-mAx-'s Avatar
Maxime Perelli
can you provide your .model file (or create a simple one)
I'll try to import it into gambit
Old   January 11, 2011, 22:56
J.-H. Wang
How come you will NEED to mesh your geometries in CATIA anyway? It doesn't do you any good...
If you are trying to avoid switching softwere all the times, you can try ANSYS workbench. The work flow is user-friendly and it is easy connect pre, solver and post. But if you are trying to avoid the steps in Gambit, how come you need to import the file to it.... It's really confusing...
This is my workflow, it is simple but it is efficient after some experiences.
CATIA(V5): output .stp => Gambit: meshing and B.C. => Fluent
Old   January 12, 2011, 00:47
-mAx-'s Avatar
Maxime Perelli
And here is mine:
ProE: output .stp => Gambit: meshing and B.C. => OpenFOAM
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Input datafiles into the GAMBIT Kevin FLUENT 4 June 21, 2008 05:20
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Gambit input files Riaan FLUENT 1 January 14, 2005 09:12
Input Geometry from Ideas to Gambit Knick FLUENT 2 December 11, 2002 03:59
